After updating to the last release i get the following error never encountered before:
2018-07-23 12:03:33 ERROR (MainThread) [homeassistant.bootstrap] Error loading /home/homeassistant/.homeassistant/configuration.yaml: Secret allowed_chat_ids3 not defined
I checked all the entries related to telegram and it seems all ok, but also after deleting all the entries related to telegram i still get this error…
Only thing i did was resetting my smartphone.
Maybe you accidentally left the secret in.
Just search for it in your config file - or files - in case you’re using split config files.
It has to be somewhere - HA is not making it up
That’s really strange then.
Maybe try to define the secret in your secrets.yaml and see what happens then.
Maybe you get an error with a more specific location to look at.
That’s even more strange. Are you sure you’re looking at the correct set configuration files?
I’d do a system-wide grep for the secret name to see where it pops up: # grep -rl allowed_chat_ids3 /
