Hello.
I need some help with Node Red.
I’m trying to get the value of a person (home, not_home) and set that value to a text helper.
The goal is to use the texthelper to trigger automations. This way I can easily test the automations since I can manually set the value.
The problem I’m facing it to set a helper value from node red.
I’ve tried with a function node setting Global.Set(“helper”, “home”).
I’ve tried just passing the value to a call service node to set the value but I cant see any change in the helper, even though it calls the service without errors.
