I have HA Container installed on a Pi 4 running Raspbian 64bit, and I want to experiment with the voice features.
I’ve got Piper up and running, using the rhasspy/wyoming-piper image, but I can’t find an image to install Whisper. I read that rhasspy/wyoming-whisper was the way to go, but when I try to pull that image onto the Pi I get the following:
no matching manifest for linux/arm/v8 in the manifest list entries
Does anyone know of a different image I should be using, or if I’m doing something wrong with docker?
EDIT: Yes, I’ve read that running Whisper on a Pi will be slow. I’m looking to test it out, not use it properly. I’ll probably have to look into getting some beefier hardware to run local STT in the future.
Thanks, I put that into a compose file and it did pull the image.
But it exited with code 159 - I could have sworn I installed raspbian 64bit, and when I checked with uname -m earlier it gave me aarch64 - but I just read that’s the kernel not the OS. So I think I was wrong and that the OS is actually 32bit.
I couldn’t get it working. I had to run Whisper on a different server afterwards. I think I’ll probably reinstall the OS on my Pi to be 64bit - but that’s a thing for a day off. Even so, I expect I’ll still keep Whisper running on a more powerful device.
There’s somewhere here my post about running Frigate 64bit in docker. My Rasp4 kernel is 64bit, but os 32bit but still I managed to run it 64bit. And it’s been running ever since.
