Gewiss 4 gang switch recomendation
I have a 4 gang (in line) gewiss light switches at my place which I want to smartify.
I am having trouble finding either a single device with 4 switches that fits the dimensions, or even single light modules that are compatible with the gewiss standard.
in terms of specifications. the box is 140mm (5.5 inches) in length, and my electricity is 240v.
I would like it to be using the zigbee protocol as I’ve already have a couple of other zigbee devices, but considering I’m fairly new to the smart home scene, I’m open to any recommendations.
Not sure if Gewiss switches are wired differently from any other switch, but I’m guessing any zigbee module (either behind the switch or in the ceiling) should work.
If not, Gewiss themselves have their own zigbee modules which should work, though obviously you need 2 modules per 4-gang switch Gewiss GWA1522 control via MQTT | Zigbee2MQTT
