with Bluetooth getting more attention in home assistant, I wanted to ask if anybody every tried to include the „Gira system 3000“. It works with Bluetooth (smartphone app is available).
I’m using the thermostat (didn’t plan on using home assistant when installing them …) and it would be nice to be able to include them.
Just bought a home fitted with gira 3000 and also looking into possible solutions, did you ever find anything?
I suppose via a Bluetooth bridge it should be possible.
Unfortunately I didn’t find anything, but I also didn’t check anymore. Thinking about contacting GIRA but I don’t think they will provide any information.
Ok, thanks for the answer.
I found one repo → GitHub - leoyn/gira-home-assistant: Home Assistant Integration for Gira Homeserver 🏠🔗
However it does not say if it’s for Gira 3000 or another of their system (like the 1000€+ Gira HomeServer - honestly not sure who still buys into this overpriced system)
I’ll probably change for manufacturer that is better supported.
Gira is not giving away any information about their services and so on. So until no one reverse engineers that we can’t do anything.
I personally don’t have the time to do that.
I personally changed my switch to shelly switches (with their cover plate) and resold the GIRA ones.
I’ll stay away from this brand knowing their proprietary strategy to lock you in overpriced product…
It doesnt look like anyone has figured that out yet. Their system is simply too closed and they dont want you to be able to use it with anythign else… best to stay away
I also got Gira System 3000 installed. Problem is there is a wind meter connected to a central switch which uses a master slave pattern to protect shades from high winds. So not too easy to replace. The wind meter from Gira I had to replace, since it seemed to have picked up some frequencies from parallel PV cables, but I was able to use an ESP32 with esphome & a shelly to switch the Gira 3000 master on wind alarm.
Im now working on integrating the thermostats. I started with the target snd current temperature which are advertised via BLE.
I can already read the values but i want to verify with more data.
So please send me some advertising data blocks together with the current values (target and current temperature) that you can read from the device.
I recorded the packages with „BLE scanner“ on iOS. But there are probably plenty other apps or possibilities.
They look like this:
0x84051B733214F7006501FF10010000
Starting with 0x8405 and so on
@clentfort Does your device need persistant pairing? Im using a esp32 device as proxy. But that doesn’t support persistant pairing and without it, I cant connect to the thermostat. And I’m not sure if a usb BLE stick can handle the full distance.
Btw: receiving the target and current temperature works fine since this is done via advertising
@Weasel99 I have the “Jal+Schaltuhr”. They don’t feature a thermometer. All they advertise is current position. So I can help you with any measurements.
Regarding the pairing: they use ble for advertisement but to control the covers you need to pair and connect to them. Once you send the command you can disconnect again.
I had to fiddle with the Bluetooth settings on my raspberry pi a bit to manage to connect to all of the devices. Specifically increase timeouts by a lot.
Ah okay you are using the rapsberry Pi BLE. I have a mini pc with a Intel n100 and only Bluetooth Proxies. And that doesnt work. I ordered a BLE usb Stick and will try again as soon as i get it.
Reading the messurement data and having a nice Config Flow with Automatic detection is already Done
