GIRIER Tuya ZigBee 3.0 Light Switch Module 2 gang not detecting properly in HA
Hi all,
i have been using the tuya 2gang switch with tuya app and was working fine, and now i have moved to HA form last 15 days looks like the best ever solution for smart home. all the Zigbee and wifi devices are migrated sucessfuly beside the GIRIER 2 gang zigbee relays. it’s detecting a different type of wall mount switch and not doing on and off.
https://www.aliexpress.com/item/1005003417422886.html?spm=a2g0o.order_list.order_list_main.30.13681802h93QkP
Hi Fida Hussain,
I am going to assume you are using ZHA.
ZHA.
Look there to see if your device is supported or if someone has a quirk files to tide you over until it is supported assuming it is not.
If you are looking at how to use the quirks, https://community.home-assistant.io/t/zigbee-guide-how-to-setup-local-custom-device-handler-quirks-in-zha-integration/683473.
Has a discussion about it.
Hi Sir,
first of all i am really thankful for your reply, i am using zigbee2MQTT and same module of relay with 1 gang is working fine however the 2 gang is not and it’s detecting as a different module https://www.aliexpress.com/item/1005006044381632.html?spm=a2g0o.productlist.main.45.719a0QfG0QfGvC&algo_pvid=f43cd124-52b6-4916-8a4f-f25bd726044e&algo_exp_id=f43cd124-52b6-4916-8a4f-f25bd726044e-22&pdp_npi=4%40dis!SAR!65.99!42.89!!!119.90!77.93!%402141112117275868508175571e6746!12000036713521374!sea!SA!116009133!X&curPageLogUid=hXanoIXY1mmp&utparam-url=scene%3Asearch|query_from%3A
Hello @fida.hs
Do you have any updates? Have you solved the issue with the 2 gang switch?
