Gismeteo Weather provider
Hi. I don’t see attributes snow, rain and other.
Configuration.yaml:
weather :
  - platform: gismeteo
    mode: daily
Sensor.yaml:
    monitored_conditions:
      - weather
      - clouds
      - rain
      - snow
      - storm
      - geomagnetic
I see only on screenshot.
Why this not worked correctly?
Because you created sensors with these settings, and for some reason look for data in the weather object.
All are work correctly.
This component can be used in two different ways: as a weather provider for any given coordinates and as a set of sensors for current coordinates of a house.
Where i can find this sensors?
I don’t see they in sensors list.
If you can’t find them, maybe file sensor.yaml are not loaded as part of config. I’m sorry, it’s not a component bug. Check your configs.
In latest HA 2021.2.3 Gismeteo integration went unavailable. Running core venv install, checked in HACS and configuration.yaml, reinstalled via HACS- nothing. Also no entries in logs about it :frowning:
Anyone else? Some breaking change?
Best, JR
PS Saw that there is a issue filed on Github so nothing wrong at our side :slight_smile:
It’s was not a this component bug – but Gismeteo bug. Invalid data response from server.
But now server send correct response. And I published new version of component with additional server response checks.
Thanks for quick fix :slight_smile:
Best, JR
I’m fix nothing.
mdi:weather-partlycloudy was changed to mdi:weather-partly-cloudy. Fix it please to correct icon view.
weather integration: change partlycloudy to partly-cloudy
So is it possible to get a weather forecast with this somehow? I am thinking about linking to Google Assistant to get a spoken forecast that is more accurate than the default provider. I’m sure it will take a little work my end, but if this service allows me to query prediction for a particular component (e.g. rain) at a particular time (or time interval) then I can work with that to get something up and running I hope.
Thank you.
Gismeteo Weather Provider v2.1.0
A major update to the Gismeteo Weather Provider component has been released.
  • To improve the reliability and speed of operation, the component has become asynchronous.
  • In addition, internal tests have been added, which, at the development stage, constantly check the correctness of the operation of each individual piece of the component.
  • And finally, the ability to integrate a component through the Home Assistant GUI has been added.
UPD: And minor feature: added sensor for current temperature of water.
Have a nice day!.. :wink:
Hello
can not make integration with HA.
Не подключается интеграция - выдает ошибку
Статус системы
Версия core-2021.2.0
Тип установки Home Assistant Container
Среда разработки false
Supervisor false
Docker true
Виртуальное окружение false
Версия Python 3.8.7
Семейство операционных систем Linux
Версия операционной системы 3.10.35
Архитектура ЦП x86_64
Часовой пояс Europe/Moscow
2021-03-02 11:31:04 ERROR (MainThread) [aiohttp.server] Error handling request
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 422, in _handle_request
resp = await self._request_handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 499, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 118, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/security_filter.py”, line 56, in security_filter_middleware
File “/usr/src/homeassistant/homeassistant/components/http/request_context.py”, line 18, in request_context_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 72, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/config/config_entries.py”, line 136, in post
return await super().post(request)
File “/usr/src/homeassistant/homeassistant/components/http/data_validator.py”, line 60, in wrapper
result = await method(view, request, *args, **kwargs)
File “/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py”, line 69, in post
result = await self._flow_mgr.async_init(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 130, in async_init
result = await self._async_handle_step(
File “/usr/src/homeassistant/homeassistant/data_entry_flow.py”, line 213, in _async_handle_step
result: Dict = await getattr(flow, method)(user_input)
File “/config/custom_components/gismeteo/config_flow.py”, line 95, in async_step_user
default=self.hass.config.get(CONF_FORECAST, False),
AttributeError: ‘Config’ object has no attribute ‘get’
Пожалуйста, откройте багрепорт вот тут в соответствии с предложенным шаблоном: https://github.com/Limych/ha-gismeteo/issues/new?assignees=&labels=bug&template=bug_report.md&title=
Hi there! Can’t figure out how to add several locations for sensors to be able to layout them at lovelace? There is an error [latitude] is an invalid option for [sensor.gismeteo]. Check: sensor.gismeteo->latitude.
My yams is
      latitude: 59.834...
      longitude: 30.403...
        - condition
        - temperature
        - wind_speed
        - pressure
      latitude: 60.544...
      longitude: 30.409...
        - condition
        - temperature
        - wind_speed
        - pressure
In YAML, there is no way to specify geographic coordinates for sensors. Sensors are created strictly only for coordinates from the basic settings of your HA.
This happened for historical reasons. And now I see no reason to change this behavior, because the current approach of creating the weather entity in one place, and the sensor entities in another, is very inconvenient to process.
If I change the behavior of the component, then it is reasonable to transfer all settings into one block in YAML. But this will require reconfiguring all HA instances that use this component.
И, да, можно по-русски, если так удобнее… Всё равно этим компонентом пользуются преимущественно только в СНГ, где все прекрасно понимают русский язык.
Привет! Спасибо за классную интеграцию!
А все таки, можно из нее вытащить данные для двух точек?
Хочется знать температуру дома и на даче.
Есть два пути:
Либо создать два объекта weather и брать данные из их атрибутов.
Либо создать конфигурации полностью через пользовательский интерфейс HA.
Объект создался, но без сенсоров.
Можно конечно их руками в template прописать. Или это баг?
Как я могу ответить на этот вопрос не видя исходных данных и логов?
