Hi, I’m trying to use a Github codespace to test a add-on, but it’s not working.
When I open the homeassistant container in the devcontainer, it gives this in the logs:
2022-07-15 09:40:35.932 ERROR (MainThread) [homeassistant.components.http.forwarded] A request from a reverse proxy was received from 127.0.0.1, but your HTTP integration is not set-up for reverse proxies
Also, the observer says it’s disconnected. Not sure if related…
Home assistant does seem to be working, since the landingpage is working for some seconds.
Here is the .devcontainer file: asterisk-hass-addons/devcontainer.json
What it the best way to fix this? My own HA server is too little to build the add-on, and WSL2 is acting very weird for me (it takes 5 minutes to do a simple ls
Is there a way to get a custom configuration.yaml
to homeassistant in the devcontainer? Any help is appreciated!
