A Home Assistant theme inspired on GitHub.
Preview
Preparation
- Make sure that under the configuration.yaml file you have the following:
frontend:
themes: !include_dir_merge_named themes
- Under the Home Assistant Config folder, create a new folder named themes
- Restart Home assistant to apply the changes.
HACS installation
- Go into the Community Store (HACS)
- Search for GitHub Dark Theme
- Open the theme
- Press Install
- Restart Home Assistant
Manual installation
- In the Home assistant themes folder, create a file named
github_dark_theme.yaml - In this GitHub repo, go into the themes folder, open the
github_dark_theme.yamlfile and copy the content - Paste the content in the
github_dark_theme.yamlfile created under your Home Assistant themes folder
Enable theme
- Open your Home Assistant Profile
- Under, Themes , select the new GitHub Dark Theme
The frontend supports themes. This category is for sharing themes.
