Probably a dumb idea but I thought I’d look at using a Github sensor instead of rest sensors to get some version information for some github repos.
ok why isn’t this working?
- platform: github
access_token: !secret github-access-token
entity_namespace: github
repositories:
- path: 'artisan-roaster-scope/artisan'
- path: 'docker/compose'
name: Github Docker Compose
- path: 'arendst/Tasmota'
It uses the name for the friendly name but it’s supposed to overide the sensor name as well.
It is ignoring the namespace
I am getting sensor.artisan, sensor.compose, etc why not sensor.github.artisan etc??
i dont use this sensor, but it appears that it’s naming the entity based off the repo name, not the user/repo or org/repo like maybe you’re expecting?
Also, going off the documentation , entity_namespace isn’t a valid thing.
jon102034050:
entity_namespace
It works for other integrations. It is valid.
Yeah but the docs specifically say you can overide that.
carltonb
(Carlton Brooks)
February 14, 2020, 4:34am
4
DavidFW1960:
rtisan-roaster-scop
I was an artisan cacao bean roaster at one point in my life. This would have been very useful tool.
hm, never knew about the entity_namespace, is it getting deprecated?
These options are being phased out and are only available for single platform integrations.
Don’t know… maybe…
Docs here if anyone is interested:
The docs for the integration seem to say it should work with the friendly name anyway… It’s just annoying I suppose but not really a big deal.
using this myself (and note the HA repo from the example in the documentation doesn’t create a sensor…whihc is remarkable to say the least:
- platform: github
access_token: !secret github_token
entity_namespace: Github
scan_interval: 3600
repositories:
- path: home-assistant/home-assistant
- path: thomasloven/hass-browser_mod
- path: dnguyen800/air-visual-card
- path: thomasloven/lovelace-auto-entities
- path: custom-cards/bar-card
- path: custom-cards/bignumber-card
- path: custom-cards/button-card
- path: thomasloven/lovelace-card-mod
- path: thomasloven/lovelace-card-tools
# - path: custom-cards/config-template-card
# name: Config template
- path: maykar/custom-header
# - path: iammexx/home-assistant-config/tree/master/ui/darksky
# name: Darksky weather card
- path: custom-cards/decluttering-card
- path: custom-cards/entity-attributes-card
name: Entity attributes
- path: thomasloven/lovelace-fold-entity-row
name: Fold entity row
- path: custom-cards/gauge-card
- path: custom-cards/group-card
- path: thomasloven/lovelace-layout-card
- path: DBuit/light-popup-card
- path: iantrich/list-card
- path: gadgetchnnel/lovelace-card-templater
name: Card templater
- path: kalkih/mini-graph-card
- path: kalkih/mini-media-player
name: Mini media player
- path: benct/lovelace-multiple-entity-row
name: Multiple entity row
- path: gurbyz/power-wheel-card
- path: iantrich/restriction-card
- path: custom-cards/secondaryinfo-entity-row
name: Secondary info row
- path: kalkih/simple-weather-card
- path: thomasloven/lovelace-slider-entity-row
name: Slider entity row
- path: thomasloven/lovelace-state-switch
# - path: bramkragten/custom-ui/tree/master/swipe-card
# name: Swipe
- path: thomasloven/lovelace-template-entity-row
name: Template entity row
# - path: rodrigofragadf/lovelace-cards/tree/master/tiles-card
# name: Tiles
- path: thomasloven/lovelace-toggle-lock-entity-row
name: Toggle lock entity row
- path: ofekashery/vertical-stack-in-card
name: Vertical stack in card
- path: royto/waze-card
- path: sgttrs/lovelace-weather-card-chart
name: Weather card chart
which works perfectly, except for the commented repos, which cause the complete sensor to stop being created. Just filed an issue for that.
error displayed:
GitHub error for custom-cards/config-template-card: 401 {'message': 'Bad credentials', 'documentation_url': 'https://developer.github.com/v3'}
displaying these in the frontend with:
- type: custom:auto-entities
card:
type: entities
# title: Github repos
show_header_toggle: false
header:
type: picture
image: /local/images/github_owler.png
entities:
- entity: automation.github_repo_update
secondary_info: last-triggered
filter:
include:
- entity_id: sensor.github*
options:
# tap_action:
# action: more-info
type: custom:template-entity-row
state: >
{% if state_attr(config.entity,'latest_release_url') %}
{{ state_attr(config.entity,'latest_release_url').split('tag/')[1]}}
{% else %} Not set
{% endif %}
secondary: >
{{ state_attr(config.entity,'latest_commit_message')}}
only wish left is to have a tap_action, which now isn’t availble on the template-entity-row. Ive asked Thomas, but hasn’t responded yet.
even got an automation to notify of a change:
automation:
- alias: 'GitHub repo update'
platform: event
event_type: state_changed
condition:
- condition: template
value_template: >
{{ trigger.event.data.entity_id.startswith('sensor.github')}}
value_template: >
{{ 'old_state' in trigger.event.data and 'new_state' in trigger.event.data and
trigger.event.data.new_state.attributes.latest_release_url !=
trigger.event.data.old_state.attributes.latest_release_url }}
service: notify.system
data_template:
title: Github repo update
message: >
{{state_attr(trigger.event.data.entity_id, 'name')}} was updated to {{state_attr(trigger.event.data.entity_id, 'latest_release_url').split('tag/')[1]}}.
Visit the release page {{state_attr(trigger.event.data.entity_id, 'latest_release_url')}} to download.
So you do have the entity_namespace working? I just can’t make that work. Do you see an error with my configuration in first post?
oddly enough Ive just discovered only the home-assistant sensor is not getting the prefix Github, all the others do.
only difference I see is you quote all repos, and I left that out.
did you check the correct setting for the credential, like the docs state? Sure you did, just checking the only thing that could go wrong…
Yeah I removed the quote as per your example. My token seems to be working - all sensors created it just ignores the entity_namespace for some inexplicable reason
maybe add it to the issue n Github. I’ve done that today for another issue (invalid repos blocking the full sensor creation for all the valid ones) and the author is having a look. Maybe he can check this too while he’s at it
