I’m trying to setup GitLab CI using the check_config script.
My current failure:
- Component error: breaking_changes - Integration 'breaking_changes' not found.
- Platform error sensor.school_holidays - Integration 'school_holidays' not found.
- Component error: alexa_media - Integration 'alexa_media' not found.
- Component error: docker_monitor - Integration 'docker_monitor' not found.
- Component error: hacs - Integration 'hacs' not found.
- Component error: switcher_aio - Integration 'switcher_aio' not found.
- Component error: shelly - Integration 'shelly' not found.
- Platform error media_player.alexa - No module named 'homeassistant.components.alexa.media_player'
It seems that the check_config script doesn’t know how to handle the custom components as they’re not part of the source code. Any idea on how to get around this nicely ?
This would not make sense from a CI perspective, I think creating a sub-module for each of the custom components is the right way to go, although I haven’t got it working yet.
The point of check_config is to check your configuration, if you fetch the custom component another way you may be testing your configuration against a different version of the custom component to the one you’re running.
You’re making this way too complicated, just un-ignore the custom_components directory.
