Since some slightly unknown time ago - I have been away for a couple of weeks and many updates have auto-installed, including new versions of Home Assistant Core, HA OS and @britkat 's giv_tcp integration - my inverter is not playing nice with Home Assistant.
If I roll back to my last known good full backup from the end of May, things work again but I’ve done a lot creating of automations since then and I’d really rather avoid that if possible. If I roll back the GivTCP updates which have installed since May that doesn’t seem to help.
The inverter had a firmware update for the battery yesterday but that didn’t seem to make any difference.
Any advice on where to start poking things would be much appreciated.
GivTCP’s log from startup is below, the error at the bottom repeats constantly.
023-08-03 12:59:07,132 - startup - [CRITICAL] - HA MQTT Service has been found at core-mosquitto
2023-08-03 12:59:07,144 - startup - [INFO] - Supervisor Timezone: Europe/London
2023-08-03 12:59:09,159 - startup - [INFO] - Networks available for scanning are: {0: '192.168.1.1', 1: None}
2023-08-03 12:59:09,159 - startup - [CRITICAL] - Scanning network for inverters...
2023-08-03 12:59:09,160 - startup - [INFO] - Scanning network (1):192.168.1.1
2023-08-03 12:59:10,398 - startup - [INFO] - 1 Inverters found on 192.168.1.1 - {1: '192.168.1.117'}
2023-08-03 12:59:10,599 - startup - [CRITICAL] - Inverter SA2246G688 which is a Gen 1 - Hybrid has been found at: 192.168.1.117
2023-08-03 12:59:10,602 - startup - [INFO] - 1 Inverters found on None - {1: '192.168.1.117'}
2023-08-03 12:59:10,810 - startup - [CRITICAL] - Inverter SA2246G688 which is a Gen 1 - Hybrid has been found at: 192.168.1.117
2023-08-03 12:59:10,812 - startup - [CRITICAL] - GivTCP isAddon: True
2023-08-03 12:59:10,812 - startup - [CRITICAL] - Config directory already exists
2023-08-03 12:59:10,828 - startup - [CRITICAL] - Running Redis
2023-08-03 12:59:10,829 - startup - [CRITICAL] - Setting up invertor: 1 of 1
2023-08-03 12:59:11,001 - startup - [CRITICAL] - Recreating settings.py for invertor 1
2023-08-03 12:59:11,015 - startup - [CRITICAL] - Running RQ worker to queue and process givernergy-modbus calls
2023-08-03 12:59:11,016 - startup - [CRITICAL] - Running Invertor read loop every 5s
2023-08-03 12:59:11,029 - startup - [CRITICAL] - Subscribing MQTT Broker for control
2023-08-03 12:59:11,042 - startup - [CRITICAL] - Starting Gunicorn on port 6345
2023-08-03 12:59:11,061 - startup - [CRITICAL] - Creating web dashboard config
2023-08-03 12:59:11,064 - startup - [CRITICAL] - Serving Web Dashboard from port 4321
2023-08-03 12:59:11,156 - startup - [CRITICAL] - Setting daily charge target forecast job to run at: 00:20
[2023-08-03 12:59:11 +0100] [37] [INFO] Starting gunicorn 21.2.0
[2023-08-03 12:59:11 +0100] [37] [INFO] Listening at: http://0.0.0.0:6345 (37)
[2023-08-03 12:59:11 +0100] [37] [INFO] Using worker: sync
[2023-08-03 12:59:11 +0100] [49] [INFO] Booting worker with pid: 49
[2023-08-03 12:59:11 +0100] [50] [INFO] Booting worker with pid: 50
[2023-08-03 12:59:11 +0100] [51] [INFO] Booting worker with pid: 51
UPDATE The latest version of `serve` is 14.2.0.
2023-08-03 12:59:14,974 - Inv1 - mqtt_client - [CRITICAL] - Connecting to MQTT broker for control- core-mosquitto
INFO: Accepting connections at http://localhost:4321.
2023-08-03 12:59:23,450 - Inv1 - read - [ERROR ] - Consecutive failure count= 9 -- (<class 'Exception'>, Exception("Garbage or failed inverter Response: ERROR:-(<class 'KeyError'>, KeyError(HR:243), <traceback object at 0x7f7f42bec0>)"), <traceback object at 0x7f97275d40>)
