Givenergy: using automation to set a timed charge schedule into slot 1
Hello. I am new here, and to Home Assistant. I’ve spent the day trying and searching (and asking AI for help), but to no avail.
I’d like to use Home Assistant to set a timed charge into Slot 1.
However, despite the fact that my automation code should set the start and end charge times, this isn’t working. So I’m doing something wrong.
 - target:
      entity_id: select.givtcp_ab1234c567_charge_start_time_slot_1
      option: >
        {{ (states('input_datetime.power_up_start_time') |
        as_datetime).strftime('%H:%M:%S') }}
    action: select.select_option
Can anyone tell me, please, how the automation can set a charge start and end time, please? Or point me to the right documentation?
THanks in advance for any guidance!
Hi Walders, did you get any replies??
I’m new here too. I created automations to set battery time slot 1 start and stop times.
My automation contacts the inverter but it sets the time to 00:00 instead of what I want.
I see the YAML code sets the time as hh:mm:ss but the inverter entity needs hh:mm
I have no idea what to change to get that sent to the inverter???
I fixed my issue. My bad!! I chose the incorrect entity. I re-selected the correct one and hey presto, a time selector appeared. I selected the correct times and it just works…
Hope you get some luck with your issue.
