Hiya, wonder if anybody is having issues with givtcp2
i have set up my HA and installed the broker with local user and then GIVTCP
However it juts always fails to connect. i can access my GivEnergy locally so i know its there haha and it also exports to the invertor app every 10 secs so i know the data is there. here is my log. if anybody can shed any lite that would be great. i have tried it as a AIO and also using the old firmware toggle
2024-04-01 14:07:53,316 - startup - [CRITICAL] - HA MQTT Service has been found at core-mosquitto
2024-04-01 14:07:53,337 - startup - [INFO] - Supervisor Timezone: Europe/London
2024-04-01 14:07:55,365 - startup - [CRITICAL] - Scanning network for GivEnergy Devices…
2024-04-01 14:07:59,529 - startup - [CRITICAL] - Inverter CE####### which is a Gen 1 - AC has been found at: 10.0.0.14
2024-04-01 14:07:59,531 - startup - [INFO] - Searching for Inverters again
2024-04-01 14:07:59,547 - startup - [CRITICAL] - Running Redis
2024-04-01 14:07:59,566 - startup - [CRITICAL] - Setting up invertor: 1 of 1
2024/04/01 14:07:59 [notice] 69#69: using the “epoll” event method
2024/04/01 14:07:59 [notice] 69#69: nginx/1.20.2
2024/04/01 14:07:59 [notice] 69#69: OS: Linux 6.1.73-haos-raspi
2024/04/01 14:07:59 [notice] 69#69: getrlimit(RLIMIT_NOFILE): 1073741816:1073741816
2024/04/01 14:07:59 [notice] 69#69: start worker processes
2024/04/01 14:07:59 [notice] 69#69: start worker process 74
2024/04/01 14:07:59 [notice] 69#69: start worker process 75
2024/04/01 14:07:59 [notice] 69#69: start worker process 76
2024/04/01 14:07:59 [notice] 69#69: start worker process 77
2024-04-01 14:07:59,950 - startup - [CRITICAL] - Running RQ worker to queue and process givernergy-modbus calls
2024-04-01 14:07:59,951 - startup - [CRITICAL] - Running Invertor (10.0.0.14) read loop every 5s
2024-04-01 14:07:59,966 - startup - [CRITICAL] - Subscribing MQTT Broker for control
2024-04-01 14:07:59,981 - startup - [CRITICAL] - Starting Gunicorn on port 6345
[2024-04-01 14:08:01 +0100] [81] [INFO] Starting gunicorn 21.2.0
[2024-04-01 14:08:01 +0100] [81] [INFO] Listening at: http://0.0.0.0:6345 (81)
[2024-04-01 14:08:01 +0100] [81] [INFO] Using worker: sync
[2024-04-01 14:08:01 +0100] [82] [INFO] Booting worker with pid: 82
[2024-04-01 14:08:01 +0100] [83] [INFO] Booting worker with pid: 83
[2024-04-01 14:08:01 +0100] [84] [INFO] Booting worker with pid: 84
2024-04-01 14:08:05,304 - Inv1 - mqtt_client - [CRITICAL] - Connecting to MQTT broker for control- core-mosquitto
2024-04-01 14:08:12,020 - Inv1 - read - [ERROR ] - 10 failed inverter reads in a row so removing regCache to force update…
2024-04-01 14:09:45,458 - Inv1 - mqtt_client - [ERROR ] - No serial_number found in MQTT queue. MQTT Control not available.
File “/app/GivTCP_1/mqtt_client.py”, line 402, in
client.loop_forever()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 1756, in loop_forever
rc = self._loop(timeout)
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 1164, in _loop
rc = self.loop_read()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 1556, in loop_read
rc = self._packet_read()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 2439, in _packet_read
rc = self._packet_handle()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 3039, in _packet_handle
return self._handle_connack()
File “/usr/local/lib/python3.10/site-packages/paho/mqtt/client.py”, line 3138, in _handle_connack
on_connect(
File “/app/GivTCP_1/mqtt_client.py”, line 386, in on_connect
client.subscribe(MQTT_Topic+“/control/”+GiV_Settings.serial_number+“/#”)
AttributeError: type object ‘GiV_Settings’ has no attribute ‘serial_number’
2024-04-01 14:10:21,902 - Inv1 - read - [ERROR ] - 10 failed inverter reads in a row so removing regCache to force update…
2024-04-01 14:12:36,452 - Inv1 - read - [ERROR ] - 10 failed inverter reads in a row so removing regCache to force
