I am new to HA and recently had a solar system installed using GivEnergy Inverter and battery.
I have a couple of question, below is a bit on context.
I tried the GiveEnergy Smart tariff, which is meant to forecast solar availability for the following day and charge the battery to x SoC based on that forecast, using low overnight rates, that seems to have a bug and discharges everything it imports. It is also meant to check, before the afternoon peak rate, if the battery isn’t full, it charges it, that also doesn’t work.
I have been using GivTCP to show some nice dashboard data and it has a facility to set the SoC based on a solcast forecast, I believe that that is working as my SoC target at the moment has changed from 70 to 47.
As I’m in the UK, I am on a electricity tariff that is based on 30 minute rates, with peak between 16:00 and 19:00 and the low cost overnight low rates time slots change, as does there cost also.
I have an add-on that can see those rates and changes a state to ‘On’ when it see the lowest continuous 3h block and enters that time period. So I believe I have a good method to enable an over night charge.
My questions are:
Under the devices, ‘GivTCP Control’ is an entity ‘select.givtcp_xxx_force_charge’, under this you have several options.
Normal
Running
Cancel
2
15
30
45
60
90
120
If in an automation, under an action, I change the state to ‘120’, should that set the inverter to start charging for 120 minutes or until the battery SoC reaches the Target SoC?
Second question,
How do I set the target SoC? Do I just call service, input:set number and update the number that I want it to be.
