Hope there is a cure my inverter and givtcp have stopped talking and i am getting the following error message in the log.
2023-08-03 17:36:11,336 - Inv1 - read - [ERROR ] - 10 failed inverter reads in a row so removing regCache to force update…
2023-08-03 17:37:53,346 - Inv1 - read - [ERROR ] - Consecutive failure count= 4 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9940>)”), <traceback object at 0x7f83f02140>)
2023-08-03 17:38:19,273 - Inv1 - read - [ERROR ] - Consecutive failure count= 5 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9940>)”), <traceback object at 0x7f83f00fc0>)
2023-08-03 17:38:45,105 - Inv1 - read - [ERROR ] - Consecutive failure count= 6 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9940>)”), <traceback object at 0x7f83f213c0>)
2023-08-03 17:39:10,917 - Inv1 - read - [ERROR ] - Consecutive failure count= 7 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9940>)”), <traceback object at 0x7f83f22100>)
2023-08-03 17:39:36,729 - Inv1 - read - [ERROR ] - Consecutive failure count= 8 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9940>)”), <traceback object at 0x7f83f20c80>)
2023-08-03 17:39:57,310 - Inv1 - read - [ERROR ] - Consecutive failure count= 9 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:013), <traceback object at 0x7f8cbd9880>)”), <traceback object at 0x7f83f21440>)
2023-08-03 17:40:23,128 - Inv1 - read - [ERROR ] - Consecutive failure count= 10 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbd9980>)”), <traceback object at 0x7f83f22840>)
2023-08-03 17:40:48,950 - Inv1 - read - [ERROR ] - Consecutive failure count= 11 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbe9980>)”), <traceback object at 0x7f857b4a00>)
2023-08-03 17:40:48,950 - Inv1 - read - [ERROR ] - 10 failed inverter reads in a row so removing regCache to force update…
2023-08-03 17:42:32,337 - Inv1 - read - [ERROR ] - Consecutive failure count= 4 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbed980>)”), <traceback object at 0x7f83f00c00>)
2023-08-03 17:42:58,138 - Inv1 - read - [ERROR ] - Consecutive failure count= 5 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbed900>)”), <traceback object at 0x7f83f00f00>)
2023-08-03 17:43:23,964 - Inv1 - read - [ERROR ] - Consecutive failure count= 6 – (<class ‘Exception’>, Exception(“Garbage or failed inverter Response: ERROR:-(<class ‘KeyError’>, KeyError(HR:243), <traceback object at 0x7f8cbed940>)”), <traceback object at 0x7f83f02bc0>)
2023-08-03 17:43:49,822 - Inv1 - read - [ERROR ] - Consecutive failure count= 7 – (<class ‘Exception’>,
Is there a fix for this problem?
Thanks Steve
