I have this controller connected to this LED strip.
From what I can tell I have wired it up correctly.
The problem I’m having is the only colour emitted properly is red. When I selected another colour it will either stay red or no light emitted at all. I have tried re-pairing several times.
Actually when I select green it will also show but very dimly (with brightness on full).
Here is the device signature
"node_descriptor": "NodeDescriptor(byte1=1, byte2=64, mac_capability_flags=142, manufacturer_code=4687, maximum_buffer_size=82, maximum_incoming_transfer_size=82, server_mask=11264, maximum_outgoing_transfer_size=82, descriptor_capability_field=0, *allocate_address=True, *complex_descriptor_available=False, *is_alternate_pan_coordinator=False, *is_coordinator=False, *is_end_device=False, *is_full_function_device=True, *is_mains_powered=True, *is_receiver_on_when_idle=True, *is_router=True, *is_security_capable=False, *is_valid=True, *logical_type=<LogicalType.Router: 1>, *user_descriptor_available=False)",
"endpoints": {
"11": {
"profile_id": 260,
"device_type": "0x010d",
"in_clusters": [
"0x0000",
"0x0003",
"0x0004",
"0x0005",
"0x0006",
"0x0008",
"0x0300",
"0x1000"
"out_clusters": [
"0x0019"
"242": {
"profile_id": 41440,
"device_type": "0x0061",
"in_clusters": [],
"out_clusters": [
"0x0021"
"manufacturer": "GLEDOPTO",
"model": "GL-C-008P",
"class": "zigpy.device.Device"
