I purchased 4 of the GL-S10 devices to run as bluetooth proxies. I installed them via official web installer and also directly from the ESPHome dashboard. Both yielding the same result. When I ping the devices I get about 18% packet loss and the logs, etc are constantly dropping their connection. The same issue is occurring on multiple devices. Anyone seen this?
Edit: OTA also doesn’t work because of the significant packet loss.
I found my two recently purchased GL-S10 devices would go into a reboot cycle after I configured them in Home Assistant. Not sure if it is the same issue but looked like packet loss to begin with.
I just set up one of these devices this week. I was experiencing ≈20% packet loss with ethernet - I couldn’t perform an OTA update, and the integration for the Bluetooth device I wanted to connect to wouldn’t even initialize successfully.
I switched my S10 to a wifi connection, and now I’m seeing <2% packet loss, OTA works great, and my Bluetooth integration actually functions! I wish the S10 worked well over ethernet, but for now I’m happy with wifi.
It’s worth noting that I only have one Bluetooth integration currently, and it doesn’t update states very often. Perhaps if there were more Bluetooth traffic/connections necessary, there could be a noticeable conflict with wifi.
Thanks for letting us know, so since it s working with Wifi, I tried to flash mine. It s a v2.1 version, so layout is slightly different. When I tried to flash using the webtool I can see red and green led from the USB Rx and Tx flashing, but it s stalled in “Preparing” until I have a Failed message.
Did anyone succeeded to flash a v2.1using webtool? Is there anything we need to change?
I flashed 2.1 using the webtool just today and it worked perfectly. I am, however, experiencing the Ethernet packet loss so I’m going to build my own bin to see if that helps.
Thanks for letting me know, I must do something wrong but can not figure it out. Would you mind posting a picture of the cabling for the flash? Are you using specific drivers?
I have the same issue with the 2.1 board and have resorted to modifying the YAML to connect to WiFi. I suppose I could use docker to compile an older version of the firmware and update my switch to downgrade the port to 10MFD, but I am not sure that still works. Has anyone done this recently?
