I created controls for my TV, and with it, I implemented automation that will trigger once I press the button.
I have a couple of problems:
The Name of the card is not showing.
Whatever I do the name is not showing and because of it I get disbalance in UI
My code is:- type: glance show_name: false show_state: false column_width: calc(100% / 1) entities: - entity: input_boolean.playback_buttons name: TEST tap_action: toggle - type: conditional conditions: - entity: input_boolean.playback_buttons state: "on" card: type: glance show_name: false show_state: false column_width: calc(100% / 4) entities: - entity: script.d3_rewind tap_action: toggle - entity: script.d3_stop tap_action: toggle - entity: script.d3_play tap_action: toggle - entity: script.d3_forward tap_action: toggle - entity: script.d3_left tap_action: toggle - entity: script.d3_right tap_action: toggle - entity: script.d3_up tap_action: toggle - entity: script.d3_down tap_action: toggle
The menu that is triggered once I press the button it is not formatting as it should.
From the image below you can see that the generated layout looks different than intended
I want to have 2 rows of 4 buttons but for some reason, it is not generating correctly.
The code above is showing that as well.
Any suggestion would be greatly appreciated.
I am new in Home Assistant and a lot of my code is “Frankensteined”
I probably did something wrong but cant wrap my head oround it.
