Glances with Influxdb and Grafana
I’m running a few servers at home which I monitor through Glances which works perfectly, last weekend I added Influxdb and Grafana to monitor over long time. I created the following dashboard, see picture:
As you can see, the data for the CPU is fine, but for Speicherbelegung and Arbeitsspeicherauslastung it’s not displayed. However, in Home Assistant it’s visible. What would be the best way to start troubleshooting, logs and so on?
I would turn on debugging for influxdb in the HA logging: section which should indicate what data is being sent - but I have never had to do it.
You could also query the database using the influxdb query language, but you would have to look up on their website on how to do it - I did that initially but can’t remember the syntax now.
