Glaswerk Styler The theme studio for Home Assistant
Hi everyone,
I’d like to introduce Glaswerk Styler, a theme studio for Home Assistant 2026.10 and later. You can install it straight from the Marketplace.
What is it?
Glaswerk adds its own panel to the sidebar, where you build a complete theme without touching YAML. It is built on Home Assistant 2026’s new colour layer: from 15 decisions, HA derives 51 fill colours and 19 text colours. What you get is a plain theme file that you can share or edit by hand at any time.
:play_button: Watch the 2½-minute video. Clicking the image opens it on YouTube:
Glaswerk Styler – Video
What’s included
  • Studio: open any existing theme, including other people’s. Anything Glaswerk doesn’t know stays untouched. There are 475 fields in eight steps, and every group says in one sentence what it is for.
  • Kit: ready-made parts for palette, font, corners, density, card style and background. It includes 15 colour palettes, among them macOS, Android, Nord, Solarized, Catppuccin and Gruvbox.
  • Control bar for dashboards: a menu, fullscreen (remembered per device), and quick sliders for transparency, blur and text size. A settings window modelled on the Mac’s System Settings is included too. Every change is written straight into the theme file.
  • Badge for the badge row: light, auto, dark and fullscreen.
  • 19 UIX templates for UI eXtension, with before and after previews.
  • Bubble Card and Mushroom read their colours from the same layer.
  • Backups: every write keeps the previous version, and one click brings it back.
  • Five languages: English, German, French, Dutch and Spanish. Glaswerk follows Home Assistant’s language; any other language gets English.
Install via the Marketplace (HA 2026.11 and later)
Open in Home Assistant
  1. Click the button. To do it by hand: Settings → Marketplace → Add from link → Piranha1605/glaswerk-styler
  2. Open Glaswerk and install it. The setup opens by itself afterwards.
On HA 2026.10, use HACS → Custom repositories → https://github.com/Piranha1605/glaswerk-styler, type Integration. If you already installed Glaswerk through HACS, you don’t need to do anything when you move to 2026.11, because it moves to the Marketplace with everything else.
UI eXtension is only needed for the UIX templates.
Links
If you already use HATG: it stays in service, and both can be installed side by side. Glaswerk is the second, simpler way.
Feedback, bug reports (GitHub issues welcome) and screenshots of your themes are very welcome. I’d especially like to hear from you about the translations.
If you like Glaswerk: Buy me a coffee :hot_beverage:
Hi
Thanks for the share but unhappy all in german if I detect it right is not much interest for most people :frowning: Do you plan to get at least an english version of it ?
Uninstalled straight.
Hi Vincèn,
thanks a lot for trying it and for the honest feedback – you found a real bug.
The panel is fully translated into English, but it only switched to English when Home Assistant itself was set to English. Every other language (French in your case, I guess) fell back to German. The control bar already did it the right way; the panel didn’t.
Fixed in v1.0.2: the panel now uses German only for a German interface and English for every other language.
If you give it another try, I’d be glad to hear how it works for you. A French translation could follow if there is interest.
Thanks a lot @En_Rico for your quick follow-up and fix :wink: I confirm it works fine now and displays in english in my HA setup in French so all good :ok_hand:
If you need help, I would be happy to help for french translation :wink:
