I have a Gledopto GL-C-004P light strip, which I had used with home assistant for a few weeks in the beginning of this year. Then it suddenly dropped off the network. I have removed it from Zigbee2MQTT and tried pairing it again. At first it connects, then it leaves the network. I don’t understand the log messages completely, maybe someone on here can help me.
I have attached the logs from the most recent pairing attempt on log level info, after removing entries related to all other devices. Line 36 of the pasted logs looks suspicious to me.
Edit: I have been browsing the home-assistant.log out of sheer curiosity and found the following entries as well, which are at least related to that issue:
2024-03-30 20:06:32.782 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:32.977 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:33.161 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:33.687 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:44.321 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:44.396 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:44.586 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:44.768 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
2024-03-30 20:06:45.274 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode 'xy' received for entity light.0xa4c138daf2a85754
Thank You!
Simon
info 2024-03-30 20:06:11: Zigbee: allowing new devices to join.
info 2024-03-30 20:06:30: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754/availability', payload '{"state":"online"}'
info 2024-03-30 20:06:30: Device '0xa4c138daf2a85754' joined
info 2024-03-30 20:06:31: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_joined"}'
info 2024-03-30 20:06:31: Starting interview of '0xa4c138daf2a85754'
info 2024-03-30 20:06:31: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754","status":"started"},"type":"device_interview"}'
debug 2024-03-30 20:06:31: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"modelId":"GL-C-004P"}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:31: Skipping message, still interviewing
debug 2024-03-30 20:06:31: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"GLEDOPTO"}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:31: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"powerSource":1}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:31: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"zclVersion":3}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:31: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"appVersion":1}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"stackVersion":2}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Skipping message, still interviewing
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"hwVersion":2}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20210916"}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"10151203"}' from endpoint 11 with groupID 0
info 2024-03-30 20:06:32: Successfully interviewed '0xa4c138daf2a85754', device has successfully been paired
info 2024-03-30 20:06:32: Device '0xa4c138daf2a85754' is supported, identified as: Gledopto Zigbee LED Strip Light Kit (GL-C-004P)
info 2024-03-30 20:06:32: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Zigbee LED Strip Light Kit","exposes":[{"features":[{"access":7,"description":"On/off state of this light","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","label":"Brightness","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","label":"Color temp","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495}],"property":"color_temp","type":"numeric","unit":"mired","value_max":495,"value_min":158},{"access":7,"description":"Color temperature after cold power on of this light","label":"Color temp startup","name":"color_temp_startup","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495},{"description":"Restore previous color_temp on cold power on","name":"previous","value":65535}],"property":"color_temp_startup","type":"numeric","unit":"mired","value_max":495,"value_min":158}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","label":"Effect","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"GL-C-004P","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","label":"Transition","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","label":"Color sync","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":false,"vendor":"Gledopto"},"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754","status":"successful","supported":true},"type":"device_interview"}'
info 2024-03-30 20:06:32: Configuring '0xa4c138daf2a85754'
info 2024-03-30 20:06:32: MQTT publish: topic 'homeassistant/light/0xa4c138daf2a85754/light/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","brightness":true,"brightness_scale":254,"color_mode":true,"command_topic":"zigbee2mqtt/0xa4c138daf2a85754/set","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"effect":true,"effect_list":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"max_mireds":495,"min_mireds":158,"name":null,"object_id":"0xa4c138daf2a85754","origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"schema":"json","state_topic":"zigbee2mqtt/0xa4c138daf2a85754","supported_color_modes":["color_temp"],"unique_id":"0xa4c138daf2a85754_light_zigbee2mqtt"}'
info 2024-03-30 20:06:32: MQTT publish: topic 'homeassistant/select/0xa4c138daf2a85754/effect/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/0xa4c138daf2a85754/set/effect","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"enabled_by_default":false,"icon":"mdi:palette","name":"Effect","object_id":"0xa4c138daf2a85754_effect","options":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"unique_id":"0xa4c138daf2a85754_effect_zigbee2mqtt"}'
info 2024-03-30 20:06:32: MQTT publish: topic 'homeassistant/sensor/0xa4c138daf2a85754/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c138daf2a85754_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138daf2a85754","unique_id":"0xa4c138daf2a85754_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
debug 2024-03-30 20:06:32: Received MQTT message on 'homeassistant/light/0xa4c138daf2a85754/light/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","brightness":true,"brightness_scale":254,"color_mode":true,"command_topic":"zigbee2mqtt/0xa4c138daf2a85754/set","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"effect":true,"effect_list":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"max_mireds":495,"min_mireds":158,"name":null,"object_id":"0xa4c138daf2a85754","origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"schema":"json","state_topic":"zigbee2mqtt/0xa4c138daf2a85754","supported_color_modes":["color_temp"],"unique_id":"0xa4c138daf2a85754_light_zigbee2mqtt"}'
debug 2024-03-30 20:06:32: Received MQTT message on 'homeassistant/select/0xa4c138daf2a85754/effect/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","command_topic":"zigbee2mqtt/0xa4c138daf2a85754/set/effect","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"enabled_by_default":false,"icon":"mdi:palette","name":"Effect","object_id":"0xa4c138daf2a85754_effect","options":["blink","breathe","okay","channel_change","finish_effect","stop_effect"],"origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"unique_id":"0xa4c138daf2a85754_effect_zigbee2mqtt"}'
debug 2024-03-30 20:06:32: Received MQTT message on 'homeassistant/sensor/0xa4c138daf2a85754/linkquality/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"},{"topic":"zigbee2mqtt/0xa4c138daf2a85754/availability","value_template":"{{ value_json.state }}"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0xa4c138daf2a85754"],"manufacturer":"Gledopto","model":"Zigbee LED Strip Light Kit (GL-C-004P)","name":"0xa4c138daf2a85754","sw_version":"10151203","via_device":"zigbee2mqtt_bridge_0x048727fffe1f3430"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0xa4c138daf2a85754_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.36.0","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0xa4c138daf2a85754","unique_id":"0xa4c138daf2a85754_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorCapabilities":31}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Missing colorTempPhysicalMin and/or colorTempPhysicalMax for endpoint 0xa4c138daf2a85754!
info 2024-03-30 20:06:32: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754', payload '{"color_mode":"xy","linkquality":164,"state":null}'
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorTempPhysicalMax":495,"colorTempPhysicalMin":158}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:32: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 genOnOff [{"attribute":"onOff","min":0,"max":"MAX","change":1}]
debug 2024-03-30 20:06:32: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 11 with groupID 0
info 2024-03-30 20:06:32: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754', payload '{"color_mode":"xy","linkquality":168,"state":"ON"}'
debug 2024-03-30 20:06:32: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 genLevelCtrl [{"attribute":"currentLevel","min":"10_SECONDS","max":"MAX","change":1}]
debug 2024-03-30 20:06:33: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genLevelCtrl', data '{"currentLevel":27}' from endpoint 11 with groupID 0
info 2024-03-30 20:06:33: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754', payload '{"brightness":27,"color_mode":"xy","linkquality":168,"state":"ON"}'
debug 2024-03-30 20:06:33: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 lightingColorCtrl [{"attribute":"colorTemperature","min":"10_SECONDS","max":"MAX","change":1}]
debug 2024-03-30 20:06:33: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorTemperature":495}' from endpoint 11 with groupID 0
info 2024-03-30 20:06:33: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754', payload '{"brightness":27,"color_mode":"xy","color_temp":495,"linkquality":168,"state":"ON"}'
info 2024-03-30 20:06:33: Successfully configured '0xa4c138daf2a85754'
warn 2024-03-30 20:06:33: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:34: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_leave"}'
warn 2024-03-30 20:06:34: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:35: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_leave"}'
warn 2024-03-30 20:06:35: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:36: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_leave"}'
warn 2024-03-30 20:06:36: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:37: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_leave"}'
warn 2024-03-30 20:06:37: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:38: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_leave"}'
warn 2024-03-30 20:06:38: Device '0xa4c138daf2a85754' left the network
info 2024-03-30 20:06:42: Device '0xa4c138daf2a85754' joined
info 2024-03-30 20:06:43: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754"},"type":"device_joined"}'
info 2024-03-30 20:06:43: Starting interview of '0xa4c138daf2a85754'
info 2024-03-30 20:06:43: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754","status":"started"},"type":"device_interview"}'
info 2024-03-30 20:06:43: Successfully interviewed '0xa4c138daf2a85754', device has successfully been paired
info 2024-03-30 20:06:43: Device '0xa4c138daf2a85754' is supported, identified as: Gledopto Zigbee LED Strip Light Kit (GL-C-004P)
info 2024-03-30 20:06:44: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Zigbee LED Strip Light Kit","exposes":[{"features":[{"access":7,"description":"On/off state of this light","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","label":"Brightness","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","label":"Color temp","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495}],"property":"color_temp","type":"numeric","unit":"mired","value_max":495,"value_min":158},{"access":7,"description":"Color temperature after cold power on of this light","label":"Color temp startup","name":"color_temp_startup","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495},{"description":"Restore previous color_temp on cold power on","name":"previous","value":65535}],"property":"color_temp_startup","type":"numeric","unit":"mired","value_max":495,"value_min":158}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","label":"Effect","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"GL-C-004P","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","label":"Transition","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","label":"Color sync","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":false,"vendor":"Gledopto"},"friendly_name":"0xa4c138daf2a85754","ieee_address":"0xa4c138daf2a85754","status":"successful","supported":true},"type":"device_interview"}'
info 2024-03-30 20:06:44: Configuring '0xa4c138daf2a85754'
debug 2024-03-30 20:06:44: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorCapabilities":31}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:44: Missing colorTempPhysicalMin and/or colorTempPhysicalMax for endpoint 0xa4c138daf2a85754!
info 2024-03-30 20:06:44: MQTT publish: topic 'zigbee2mqtt/0xa4c138daf2a85754', payload '{"brightness":27,"color_mode":"xy","color_temp":495,"linkquality":180,"state":"ON"}'
debug 2024-03-30 20:06:44: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorTempPhysicalMax":495,"colorTempPhysicalMin":158}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:44: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 genOnOff [{"attribute":"onOff","min":0,"max":"MAX","change":1}]
debug 2024-03-30 20:06:44: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genOnOff', data '{"onOff":1}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:44: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 genLevelCtrl [{"attribute":"currentLevel","min":"10_SECONDS","max":"MAX","change":1}]
debug 2024-03-30 20:06:44: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'genLevelCtrl', data '{"currentLevel":27}' from endpoint 11 with groupID 0
debug 2024-03-30 20:06:44: Configure reporting: true, read: true for 0xa4c138daf2a85754/11 lightingColorCtrl [{"attribute":"colorTemperature","min":"10_SECONDS","max":"MAX","change":1}]
debug 2024-03-30 20:06:44: Received Zigbee message from '0xa4c138daf2a85754', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorTemperature":495}' from endpoint 11 with groupID 0
info 2024-03-30 20:06:44: Successfully configured '0xa4c138daf2a85754'
warn 2024-03-30 20:07:04: Device '0xa4c138daf2a85754' left the network
