Hey
Bought Gledopto GL-C-201P (and GL-C-202P) paired in latest zigbee2mqtt (1.39.1-1), but it shown as GL-C-008P
Although it’s configurable from zigbee2mqtt UI light enitity was no appeared in HA entities list. Should it appeared, right?
The same situation with GL-C-202P too
What I am doing wrong ?
[2024-08-12 17:58:22] info: zh:controller: Interview for '0xa4c1380b1791413f' started
[2024-08-12 17:58:22] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b1791413f', payload '{"color_mode":"xy","last_seen":"2024-08-12T14:58:22.022Z","linkquality":94,"state":null,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null}'
[2024-08-12 17:58:22] info: z2m: Device '0xa4c1380b1791413f' joined
[2024-08-12 17:58:22] info: z2m: Starting interview of '0xa4c1380b1791413f'
[2024-08-12 17:58:22] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1380b1791413f","ieee_address":"0xa4c1380b1791413f"},"type":"device_joined"}'
[2024-08-12 17:58:22] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1380b1791413f","ieee_address":"0xa4c1380b1791413f","status":"started"},"type":"device_interview"}'
[2024-08-12 17:58:22] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b1791413f', payload '{"color_mode":"xy","last_seen":"2024-08-12T14:58:22.521Z","linkquality":94,"state":null,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null}'
[2024-08-12 17:58:22] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0xa4c1380b1791413f","ieee_address":"0xa4c1380b1791413f"},"type":"device_announce"}'
[2024-08-12 17:58:22] info: zh:controller: Succesfully interviewed '0xa4c1380b1791413f'
[2024-08-12 17:58:22] info: z2m: Successfully interviewed '0xa4c1380b1791413f', device has successfully been paired
[2024-08-12 17:58:22] info: z2m: Device '0xa4c1380b1791413f' is supported, identified as: Gledopto Zigbee LED Controller RGB+CCT (pro) (GL-C-008P)
[2024-08-12 17:58:23] info: z2m: Configuring '0xa4c1380b1791413f'
[2024-08-12 17:58:23] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Zigbee LED Controller RGB+CCT (pro)","exposes":[{"features":[{"access":7,"description":"On/off state of this light","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","label":"Brightness","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","label":"Color temp","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495}],"property":"color_temp","type":"numeric","unit":"mired","value_max":495,"value_min":158},{"access":7,"description":"Color temperature after cold power on of this light","label":"Color temp startup","name":"color_temp_startup","presets":[{"description":"Coolest temperature supported","name":"coolest","value":158},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":495},{"description":"Restore previous color_temp on cold power on","name":"previous","value":65535}],"property":"color_temp_startup","type":"numeric","unit":"mired","value_max":495,"value_min":158},{"access":7,"description":"Color of this light in the CIE 1931 color space (x/y)","features":[{"access":7,"label":"X","name":"x","property":"x","type":"numeric"},{"access":7,"label":"Y","name":"y","property":"y","type":"numeric"}],"label":"Color (X/Y)","name":"color_xy","property":"color","type":"composite"},{"access":7,"description":"Color of this light expressed as hue/saturation","features":[{"access":7,"label":"Hue","name":"hue","property":"hue","type":"numeric"},{"access":7,"label":"Saturation","name":"saturation","property":"saturation","type":"numeric"}],"label":"Color (HS)","name":"color_hs","property":"color","type":"composite"}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","label":"Effect","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect","colorloop","stop_colorloop"]},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"GL-C-008P","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","label":"Transition","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","label":"Color sync","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"Gledopto"},"friendly_name":"0xa4c1380b1791413f","ieee_address":"0xa4c1380b1791413f","status":"successful","supported":true},"type":"device_interview"}'
[2024-08-12 17:58:23] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xa4c1380b1791413f', payload '{"color_mode":"xy","last_seen":"2024-08-12T14:58:23.120Z","linkquality":91,"state":null,"update":{"installed_version":-1,"latest_version":-1,"state":null},"update_available":null}'
