Gledopto GL-SD-001 doesn't show up correctly
I have a Gledopto GL-SD-001 Triac AC Dimmer that I am trying to add to HA, but I have not had any clear success.
When I try to add the device, it shows up immediately, but instead of its make and model, it says unk_model by unk_manufacturer.
The device seems to be working as it should, but this is my first device that doesn’t get added correctly, so I’m mostly worried that there is some other problem that I don’t realize. Is it fine to continue to use the device without it being recognized correctly?
I tried adding the device multiple times since that has helped in the past. I also tried adding the device close to my Zigbee stick but without any change.
Does anyone have any ideas?
