i’ve recently bought the gledopto rgbw led controller and i’ve successufully integrated it in Home Assistant with the zigbee2mqtt addon. I can set the color, the brightness ecc… but i cant set the effects to the led strip!
I don’t know anything about this, but was curious and looked around…I came across the following…maybe it will help. Look about 2/3 way down and you’ll see someone’s HA config.
hi even with the configuration posted i still receive the same error --> zigbee2mqtt:error 3/25/2019, 7:19:59 PM No converter available for ‘effect’ (6)
As far as i know there a no light effects built in to zigbee2mqtt. You can hope that it will be built in someday or make your own automation for it in HASS…
has anyone tried to create an automation to simulate a color loop effect with Zigbee2mqtt ? I wrote one, but it seems to make Zigbee2mqtt crash, maybe too many requests ?
