Hi all,
I have a Gledopto RGBW (1ID) controller. It’s attached to an LED strip which turns on and off when motion is detected. This seems to work pretty well.
That said, I have a couple of issues:
If I set any attriubutes in node red e.g. {“brightness_pct”: 50, transition:1.5} and switch the strip on, it abruptly turns on to that colour. If I don’t set any attributes it nicely fades on. Has anyone else encountered this or found a way to make this work as intended? The strip can be quite bright and can be startling at night if it just suddenly comes on at full brightness or even half brightness.
Sometimes the ability to control the gledopto device via home assistant’s UI stops working. I can toggle the switch in the UI (or inject into my node red flow) but nothing happens. The LED strip just stays either off or on. In the zigbee2mqtt logs I can see the message is sent, but nothing actually happens. Any ideas?
With regards to number 1 above, when I turn the light on via node red I see the following message in my zigbee2mqtt log:
INFO: MQTT publish: topic 'zigbee2mqtt/gledopto1', payload '{"brightness":51,"color":{"x":0.491,"y":0.39},"color_temp":354,"linkquality":228,"state":"ON"}
I have a transition set at 2 seconds but this doesn’t appear to be passed along to the gledopto device, even though the zigbee2mqtt site lists transition time as being supported.
Thanks in advance,
C
