Global Cache itach working
First post, haven’t had much to say yet just reading everyone’s posts and learning.
I have HASOS 2023.11.2 running on a Lenovo think center M910q. I had a Phillips Pronto years ago, moved to Roomie, then to DemoPad, recently adding HA. Would like to replace DemoPad but I don’t think that’s going to happen. It works to well even though it costs me $150 per year its worth it. Only problem I have is its missing a lot of things I’d like to automate and control. Cant get Lutron Caseta lights to work for example. Its mostly a very good and stable graphical IR remote that works with IOS only.
Anyway… So… trying to get my Global Cache itachs working has been a multi day experience. Am just adding here for posterity. It seems a lot of people have unresolved problems with them. Hopefully this helps someone. from the posts I saw, everyone was helpful but major parts were missing or vaguely explained.
!NOTE!!
You MUST “restart home assistant” and not “quick load” after making changes. This messed with my head a few times. go to: settings>3 dots>restart
And you should be checking the yaml configuration before you restart.
go to: developer tools>YAML>check configuration
The IR code must be in pronto format. Pronto short codes seem to work also but the default whatever Global Cache uses wont work. Go to global cache’s web site, look for iConvert.exe if you already have working IR codes.
So I also split the configuration.yaml. I added the lines :
# define ir commands to itach for the TV and reciever
remote: !include remote.yaml
into configuration.yaml
then created the file "remote.yaml with:
# IR commands for Itach IR transmitters at the TV and audio closet to send IR codes to each
  - platform: itach #for TV
    host: 192.168.1.104
    devices:
      - name: LGTV
        modaddr: 1 # is the module number default is 1
        connaddr: 3 #this is the IR emitter port number
        commands:
          - name: "on"
            data: "0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0689 0157 0056 0015 0E94"
          - name: "off"
            data: "0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0689 0157 0056 0015 0E94"
### add 2nd device ###
#      - name: Xbox
#        modaddr: 1
#        connaddr: 3
#        commands:
#          - name: "ON"
#            data: "enter IR code in prono format here"
#          - name: "OFF"
####### add 2nd itach #######
  - platform: itach #for audio closet
    host: 192.168.1.103
    devices:
      - name: onkyo_amp
        modaddr: 1
        connaddr: 3
        commands:
          - name: "on"
            data: "0000 006D 0022 0002 0156 00AB 0015 0015 0015 003F 0015 0015 0015 0015 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 0015 0015 0015 0015 003F 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 05CC 0156 0055 0015 0E47"
          - name: "off"
            data: "0000 006D 0022 0002 0156 00AB 0015 0015 0015 003F 0015 0015 0015 0015 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 0015 0015 0015 0015 0015 0015 003F 0015 0015 0015 0015 0015 0015 0015 0015 0015 003F 0015 003F 0015 003F 0015 0015 0015 003F 0015 05F6 0156 0055 0015 0E47"
          - name: "mute"
            data: "0000 006D 0022 0002 0156 00AB 0015 0015 0015 003F 0015 0015 0015 0015 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 003F 0015 0015 0015 003F 0015 0015 0015 003F 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 0015 003F 0015 0015 0015 003F 0015 003F 0015 003F 0015 003F 0015 003F 0015 05CC 0156 0055 0015 0E47"
          - name: "vol_up"
            data: "0000 006D 0000 0022 0156 00AC 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0020 06F0"
          - name: "vol_dwn"
            data: "0000 006D 0000 0022 0156 00AC 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0020 06C5"
#      - name: dvd player
#        modaddr: 1
#        connaddr: 3
#        commands:
#          - name: "play"
#            data: "enter IR code in pronto format here"
And that works! you can test under developer tools > services" with:
service: remote.send_command
  num_repeats: 1
  delay_secs: 0.4
  hold_secs: 0
  command: "on"
  entity_id: remote.lgtv
now… to add entities so you can assign them to buttons and such, add to the scripts.yaml file:
# Scripts to make IR commands useable entities for "LGTV"
tv_on:
  alias: tv_on
  sequence:
  - service: remote.send_command
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'on'
  mode: single
  icon: mdi:remote
tv_off:
  alias: tv_off
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'off'
  mode: single
  icon: mdi:remote
# Scripts to make IR commands useable entities for "onkyo_amp"
amp_on:
  alias: amp_on
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'on'
      entity_id: remote.onkyo_amp
  mode: single
  icon: mdi:remote
amp_off:
  alias: amp_off
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'off'
  mode: single
  icon: mdi:remote
amp_mute:
  alias: amp_mute
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'mute'
  mode: single
  icon: mdi:remote
amp_vol_up:
  alias: amp_vol_up
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'vol_up'
  mode: single
  icon: mdi:remote
amp_vol_dwn:
  alias: amp_vol_dwn
  sequence:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: 'vol_dwn'
  mode: single
  icon: mdi:remote
I’ve had a few years of dealing with IR and pronto codes and such. Will post some files.
This thing wont let me add txt files. Attached the IR command files I have from Demopad’s devices export for the Onkyo TXRZ810. will need the Iconvert.exe file from Global cache to convert the “sendir,…bla,bla,numbers…” to pronto codes. pronto codes start 0000
[ONKYO_IR_Standby]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Power on]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_Mute toggle]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_VOL+5]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_VOL-5]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_VOL+1]	sendir,1:3,1,38000,1,1,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,32,1776
[ONKYO_IR_VOL-1]	sendir,1:3,1,38000,1,1,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,32,1733
[ONKYO_IR_TestTone]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_ChannelSelect]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Level_up]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Level_down]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Sub_level_select]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,22,21,22,32,1518,342,86,32,3668
[ONKYO_IR_Display_settings]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,63,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Quick Menu]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_AudioAdjust]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,21,21,1526,342,85,21,3655
[ONKYO_IR_Video Adjust]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,65,21,65,21,22,32,1518,342,86,32,3668
[ONKYO_IR_CurserUP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_CurserDOWN]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_CurserLEFT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_CurserRIGHT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_Enter]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_Return]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Store]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,1654,342,85,21,3655
[ONKYO_IR_Recall]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,1654,342,85,21,3655
[ONKYO_IR_VCR/DVR]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_CBL/SAT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_GAME]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_AUX-2]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_DVD/BD]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,21,21,1526,342,85,21,3655
[ONKYO_IR_TV/TAPE]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_PHONO]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_CD]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_FM]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,1484,342,85,21,3655
[ONKYO_IR_AM]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,1484,342,85,21,3655
[ONKYO_IR_SIRUS]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,22,21,22,21,65,21,22,21,22,32,1518,342,86,32,3668
[ONKYO_IR_TUNER]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,1484,342,85,21,3655
[ONKYO_IR_InternetRADIO]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NETAUDIO_WRAP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_Input-select-UP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,1526,342,85,21,3655
[ONKYO_IR_input-select-DOWN]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Res-THROUGH]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,65,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_Res-AUTO]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-480P]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-720P]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-1080I]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-1080P]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-1080P/24]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-SOURCE]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,65,21,22,21,22,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_RES-WRAP]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,32,1518,342,86,32,3668
[ONKYO_IR_IS-WRAP]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,22,21,22,21,65,32,1604,342,86,32,3668
[ONKYO_IR_Surround-WRAP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_THX-WRAP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_THXcinema]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,65,21,22,21,22,21,65,21,22,21,22,32,1561,342,86,32,3668
[ONKYO_IR_TVlogic]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,65,21,65,32,1604,342,86,32,3668
[ONKYO_IR_DSP-UP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,1526,342,85,21,3655
[ONKYO_IR_DSP-DOWN]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,1526,342,85,21,3655
[ONKYO_IR_LATEnight-WRAP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,1526,342,85,21,3655
[ONKYO_IR_EQcinema_WRAP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,1526,342,85,21,3655
[ONKYO_IR_STEREO]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_Listening Mode Up]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,1484,342,85,21,3655
[ONKYO_IR_Listening Mode Down]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,1526,342,85,21,3655
[ONKYO_IR_NetCommands_Play]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_STOP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_PAUSE]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_TRACK UP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_TRACK DOWN]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_FF]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_REW]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_REPEAT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_RANDOM]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_DISPLAY]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_RIGHT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_LEFT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,21,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_UP]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,63,21,21,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_DOWN]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_SELECT]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,63,21,21,21,21,21,21,21,63,21,63,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,21,21,1654,342,85,21,3655
[ONKYO_IR_NetCommands_SETUP]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,65,21,65,21,65,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,32,1647,342,86,32,3668
[ONKYO_IR_NetCommands_RETURN]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,65,21,22,32,1647,342,86,32,3668
[ONKYO_IR_TV_Logic]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,65,21,65,32,1604,342,86,32,3668
[ONKYO_IR_TV_Full Mono]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,22,21,22,21,65,21,65,32,1561,342,86,32,3668
[ONKYO_IR_AUX-1]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,63,21,63,21,21,21,21,21,63,21,21,21,21,21,21,21,21,21,21,21,63,21,63,21,21,21,1484,342,85,21,3655
[ONKYO_IR_PORT]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,22,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,22,32,1518,342,86,32,3668
[ONKYO_IR_Night Mode]	sendir,1:3,1,38000,1,69,342,171,21,21,21,63,21,21,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,63,21,63,21,21,21,63,21,63,21,21,21,63,21,63,21,63,21,21,21,63,21,21,21,63,21,63,21,21,21,21,21,21,21,63,21,21,21,63,21,21,21,21,21,1526,342,85,21,3655
[ONKYO_IR_DynamicVolume]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,65,32,1690,342,86,32,3668
[ONKYO_IR_DolbyVolume]	sendir,1:3,1,38000,1,69,342,172,21,22,21,65,21,22,21,22,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,65,32,1604,342,86,32,3668
[ONKYO_IR_TV]	sendir,1:3,1,37650,1,1,340,169,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,63,22,21,22,21,22,21,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,1454,340,84,22,3624,340,84,22,3624,340,84,22,4819
This thing wont let me do txt files. Attached the IR command files I have from Demopad’s devices export for the LG TV. will need the Iconvert.exe file from Global cache to convert the “sendir,…bla,bla,numbers…” to pronto codes. pronto codes start 0000
[LG_TV_IR_Power-toggle]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IREnergy]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,21,22,63,22,21,22,21,22,63,22,21,22,63,22,21,22,63,22,21,22,63,22,63,22,21,22,1512,342,85,22,3799
[LG_TV_IRA/V mode]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IR Input menu]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,64,22,1518,342,85,22,3810
[LG_TV_IR antenna]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,1518,342,85,22,3810
[LG_TV_IR1]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,64,22,64,22,64,22,1518,342,85,22,3810
[LG_TV_IR2]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,64,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,1518,342,85,22,3810
[LG_TV_IR3]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,1517,341,86,21,3810
[LG_TV_IR4]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,64,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,64,22,4878
[LG_TV_IR5]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,21,22,64,22,64,22,64,22,4878
[LG_TV_IR6]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,21,65,21,65,21,22,21,65,21,22,21,22,14,29,8,78,4,39,3,40,1,85,1,1838,44,2,4,3,2,2,1,8,2,10,1,57,1,11,1,4,2,10,1,8,155,86,21,3810
[LG_TV_IR7]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,1518,342,85,22,3810
[LG_TV_IR8]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IR9]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IR-/list]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,21,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IR0]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,64,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IRflashback]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,21,22,21,22,21,22,64,22,21,22,64,22,21,22,21,22,64,22,64,22,64,22,4878
[LG_TV_IRVol-up]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IRVol-down]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IRFav]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,21,64,21,64,21,64,21,64,21,22,21,22,21,22,21,64,21,22,21,22,21,22,21,22,21,64,21,64,21,64,21,1515,199,2,7,3,3,7,1,8,1,4,1,186,21,3799
[LG_TV_IRRatio]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRMute]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IRCH-up]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IRCH-dwn]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IRMenu]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRNetcast]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,21,22,64,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRQ.menu]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,64,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRup]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRRight]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IRdown]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRleft]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,64,22,64,22,64,22,1519,342,85,22,3810
[LG_TV_IRenter]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,21,22,21,22,64,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRback]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,21,22,64,22,21,22,21,22,64,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,1517,342,85,22,3810
[LG_TV_IRWidget]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,64,22,21,22,21,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRExit]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,64,22,21,22,21,22,64,22,21,22,64,22,1517,342,85,22,3810
[LG_TV_IRRed]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,64,22,64,22,64,22,21,22,64,22,21,22,64,22,64,22,21,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRgreen]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRyellow]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,21,22,64,22,64,22,64,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRblue]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,21,22,64,22,64,22,64,22,64,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IRstop]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,21,22,63,22,63,22,63,22,21,22,21,22,63,22,21,22,1513,342,85,22,3799
[LG_TV_IRplay]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,63,22,21,22,1513,342,85,22,3799
[LG_TV_IRpause]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,21,22,63,22,63,22,63,22,21,22,63,22,63,22,21,22,63,22,21,22,21,22,21,22,63,22,21,22,1513,342,85,22,3799
[LG_TV_IRREW]	sendir,1:3,1,38000,1,1,341,171,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,21,21,64,22,21,21,22,22,21,21,22,21,64,22,63,22,63,22,21,21,1514,341,86,21,3799
[LG_TV_IRFF]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,63,22,63,22,21,22,21,22,21,22,63,22,63,22,21,22,21,22,21,22,63,22,63,22,63,22,21,22,1514,342,85,22,3799
[LG_TV_IRSimplink]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,21,22,64,22,1519,342,85,22,3810
[LG_TV_IR Channel info]	sendir,1:3,1,38000,1,1,342,170,22,21,22,21,22,64,22,21,22,21,22,21,22,21,22,21,22,64,22,64,22,21,22,64,22,64,22,64,22,64,22,64,22,21,22,64,22,21,22,64,22,21,22,64,22,21,22,64,22,64,22,21,22,64,22,21,22,64,22,21,22,64,22,21,22,1519,342,85,22,3810
[LG_TV_IR_Power-off]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,65,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,1673,343,86,21,3732
[LG_TV_IR_Power-on]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,65,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,1673,343,86,21,3732
[LG_TV_IR_16:9]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,1673,343,86,21,3732
[LG_TV_IR_4:3]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,65,21,22,21,22,21,65,21,22,21,22,21,22,21,65,21,1673,343,86,21,3732
[LG_TV_IR_In service menu]	sendir,1:3,1,38000,1,69,341,171,21,22,21,21,21,66,21,21,21,22,21,21,21,22,21,21,21,65,21,64,21,22,21,64,21,66,21,64,21,66,21,64,21,66,21,65,21,22,21,64,21,66,21,64,21,66,21,64,21,22,21,21,21,65,21,21,21,22,21,21,21,22,21,21,21,1527,341,86,21,3676
[LG_TV_IR_EZAdjust]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,65,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,22,21,1673,343,86,21,3732
[LG_TV_IR_SMART]	sendir,1:3,1,38000,1,1,341,171,22,21,22,21,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,63,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,21,22,63,22,63,22,63,22,63,22,63,22,21,22,63,22,63,22,21,22,21,22,21,22,21,22,21,22,63,22,1524,341,86,22,3653,341,86,22,4878
[LG_TV_IR_My Apps]	sendir,1:3,1,38000,1,1,341,171,22,22,22,22,22,64,22,22,22,22,22,22,22,22,22,22,22,64,22,64,22,22,22,64,22,64,22,64,22,64,22,64,22,22,22,64,22,22,22,22,22,22,22,22,22,64,22,22,22,64,22,22,22,64,22,64,22,64,22,64,22,22,22,64,22,1536,341,86,22,3669,341,86,22,171
[ANTENNA ROTATE initialize]	sendir,1:1,1,36656,1,1,345,63,21,19,65,63,21,19,65,19,65,63,21,19,65,63,21,19,64,64,21,19,65,63,21,63,21,19,65,63,21,19,64,4692
[LG_TV_IR_HDMI 1]	sendir,1:3,1,38000,1,69,343,172,21,22,21,22,21,65,21,22,21,22,21,22,21,22,21,22,21,65,21,65,21,22,21,65,21,65,21,65,21,65,21,65,21,22,21,65,21,65,21,65,21,22,21,22,21,65,21,65,21,65,21,22,21,22,21,22,21,65,21,65,21,22,21,22,21,1673,343,86,21,3732
[ANTENNA ROTATE hold a]	sendir,1:1,1,36656,1,1,44,3847,172,4692
Thanks for posting this, it’s really helpful!
And great timing, too: I just started migrating from OpenHAB to HA last night, and so far Global Cache commands have been the only really tricky part to implement. You saved me a ton of time.
You are welcome.
Hope it helps!
Great post. Made it easy-peasy for this newb.
A couple notes for those that follow.
Oh, and some useful tools I found for getting codes. Of course Global Cache’s Control Tower. All the codes I was sent included pronto hex, so no conversion was required.
Also the following sources and tools:
to be continued because newb accounts can only put two links in a post . . .
. . . continued with a couple more links
All of the above discovered when Control Tower for an old device of mine didn’t have codes for all the buttons.
Good luck and thanks to all those whose effort makes something so powerful so accessible in time and money.
Newbs can only make a certain number of replies, so continuing here.
On to my next step of being able to fire IR commands through a REST end point. My ultimate goal is to use a SofaBaton X1S with a Wi-Fi “virtual device for IP control” to call the REST end point.
The following works, so just the SofaBaton step remains. Still debugging that. One thing I’ve learned is that the SoftBaton app won’t accept homeassistant.local in the URL, presumably because it wont resolve externally. I had to use the IP address to be able to save the command and that also works via curl. The app gave “please enter correct url address” as the error with the domain name.
curl -X POST -H "Authorization: Bearer <long-lived access token>" -H "Content-Type: application/json" -d '{"entity_id": "remote.living_room_tv", "command": ["input_5"]}' http://homeassistant.local:8123/api/services/remote/send_command
So far the problem is that SofaBaton is encasing my body in double quotes as if it were a string instead of a JSON map.
This input
shows up in tshark on home assistant as
"{\"entity_id\": \"remote.living_room_tv\", \"command\": [\"input_5\"]}"
Looks like it’s a known problem for at least 9 months.
http://bbs.sofabaton.com:8091/post/1823
I was able to add a Home Assistant webhook that will receive the incorrectly serialized string and parse it back out to send the command I want. entity_id: "{{ (trigger.json | from_json).entity_id }}"
Ok, I’m really dumb with this stuff but I can’t understand why HA has not made it easier to use Global Cache iTach serial and IR easier to integrate. Roomie/simple control had this years ago and the iTach have the ability to learn from the remotes.
When I purchased the HA green I never gave it a second thought that it should be so complex. I did give it a quick search, which Global Cache is listed in the devices so I made the mistake of assuming it would be much simpler.
For context I’m wanting to control an Oppo BDP-105D and an aged Sony STR-DA5300es for now. With simple control the RS-232 worked great with feedback, the Sony was flaky so I used an IR iTach with that one.
Since HA doesn’t want feedback/status report I might as well simplify things and use the IR iTach and skip the serial RS-232 on the Oppo.
Just ranting,
Just an Update:
So, I’ve had the Itachs for a long while now. Never had an issue with Demopad (since around 2011) but in home assistant they seemingly randomly stopped working. It wasn’t terrible where I gave up on them but enough I couldn’t rely on them. I found they ALWAYS responded to ping, or direct using the Global Cache app so it is/was and HA problem.
I’ve been battling it for a while now.
I have 2 of em. “AMP” is used all the time, “TV” is used maybe twice a day… maybe.
What I noticed is the AMP one rarely if ever had an issue. TV, about Twice per week, I’d have to restart HA to get it chooching again.
With that info in mind, I decided to create a “keep alive” scrypt with a bogus IR command, and setup an automation that set it off every hour.
That seems to work! It’s been 3 weeks now and hasn’t failed me.
This is a “remote” example for the TV. see the last line for the “keep alive”. it basically sends nothing.
the automation I have setup just sort of pings the ITACH every hour with that keep alive command.
it seems to have fixed my issues, going on 4 weeks of not having to restart now.
    host: 192.168.1.104
    devices:
      - name: LGTV
        modaddr: 1
        connaddr: 3
        commands:
          - name: "on"
          - name: "off"
          - name: "input_menu"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 05EE 0156 0055 0016 0EE2"
          - name: "ch_up"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 05EF 0156 0055 0016 0EE2"
          - name: "ch_dwn"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 05ED 0156 0055 0016 0EE2"
          - name: "menu"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 05ED 0156 0055 0016 0EE2"
          - name: "curser_up"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 05EF 0156 0055 0016 0EE2"
          - name: "curser_dwn"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 05EF 0156 0055 0016 0EE2"
          - name: "curser_rt"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 05EF 0156 0055 0016 0EE2"
          - name: "curser_lt"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 05EF 0156 0055 0016 0EE2"
          - name: "enter"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 05ED 0156 0055 0016 0EE2"
          - name: "back"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0040 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0040 0016 05ED 0156 0055 0016 0EE2"
          - name: "exit"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0040 0016 0015 0016 0040 0016 05ED 0156 0055 0016 0EE2"
          - name: "info"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0015 0016 0040 0016 0015 0016 05EF 0156 0055 0016 0EE2"
          - name: "antenna"
            data: "0000 006D 0000 0024 0156 00AA 0016 0015 0016 0015 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0040 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0040 0016 0040 0016 0040 0016 0040 0016 05EE 0156 0055 0016 0EE2"
          - name: "hdmi_1"
            data: "0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0041 0015 0041 0015 0041 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0016 0015 0689 0157 0056 0015 0E94"
          - name: "keep_alive"
            data: "0000 0000 0000 "
and this is the automation
alias: auto_ir_tv_keep_alive
description: ""
triggers:
  - trigger: time_pattern
    hours: /1
conditions: []
actions:
  - action: remote.send_command
    metadata: {}
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: keep_alive
mode: single
and the “script” part for the “TV keep alive”
tv_keep_alive:
  alias: tv_keep_alive
  sequence:
  - data:
      num_repeats: 1
      delay_secs: 0.4
      hold_secs: 0
      command: keep_alive
  mode: single
  icon: mdi:remote
