I have a lot of devices which are battery powered and I’d like to be notified if a battery is running low.
Unfortunately, every device type is reporting battery status a little differently. Homematic for instance has an attribute called battery
that can either be High
or Low
. My Z-Wave PIR sensors have an attribute called battery_level
which will be a percentage from 0
to 100
I didn’t want to create one template sensor/automation per device, so I came up with this:
configuration.yaml:
sensors:
low_batteries:
friendly_name: Low batteries
value_template: >-
{%- for state in states if state.attributes.battery_level or state.attributes.battery -%}
{%- set battery = state.attributes.battery_level or state.attributes.battery -%}
{%- if battery == 'High' -%}
{%- set battery = 100 -%}
{%- endif -%}
{%- if battery | int < 30 -%}
{{state.attributes.friendly_name}}
{%- endif -%}
{%- endfor -%}
battery_status:
friendly_name: Batteries
icon_template: '{% if states.sensor.low_batteries.state %}mdi:battery-10{% else %}mdi:battery{% endif %}'
value_template: '{% if states.sensor.low_batteries.state %}{{states.sensor.low_batteries.state}}{% else %}OK{% endif %}'
automations.yaml:
- alias: Low battery notification
- platform: state
entity_id: sensor.low_batteries
condition:
- condition: template
value_template: '{% if states.sensor.low_batteries.state %}true{% else %}false{%
endif %}'
- service: notify.pushover_jan
data_template:
message: 'Empty batteries: {{ states.sensor.low_batteries.state }}'
I can now add my sensor.battery_status
to my default view and see at a glance if all batteries are fine. If a battery runs low (below 30%), I will get a Pushover notification.
Note that I didn’t explicitly list any devices here. It will work with all devices (current and future) known to Home Assistant.
I’m not really happy with the result of sensor.low_batteries
, though. It will simply concatenate all friendly_name
s of devices with low batteries. I’d much rather use a list here.
Happy to hear any suggestions on how to improve this! Thanks!
