Global variables and templates
I have a security flow built around a HA Alarm control panel. I have a number of sensors on Z-Wave and the flow takes the friendly_name attribute of the most recently triggered sensor and writes it to global.alarm_trigger. Using a context browser object I can see the global variable gets set.
Plan is when the alarm is triggered this kicks off the alarm state part of the flow which will send a pushover notification.
I have a template that is trying to pull the global.alarm_trigger value into the Pushover message:
“data”:{
“title”: “HomeAssistant: Security”,
“message”: “Alarm has been activated. Detected {{global.alarm_trigger}}.”
When this runs I get:
title: “HomeAssistant: Security”
message: “Alarm has been activated. Motion detected .”
I can’t seem to get the global.alarm_trigger to be added?
Make sure you tick on the render template option in the call service node.
