Globals, store and restore RGB light values
Hi there,
I tried to set a simple light automation in esphome, but I really found difficulties in managing RGB values.
This is my project:
  1. Turn on a RGB light, I choose a color and a brightness (don’t mind what)
  2. At 7:00 RGB values are read and saved (set.globals?)
  3. RGB light color goes to green
  4. At 8:00 recall the previous values
  5. RGB light previous values are restored
This is my esp32 .yaml file
output:
  - platform: esp8266_pwm
    pin: GPIO14
    max_power: 0.75
    pin: GPIO12
    max_power: 0.75
    pin: GPIO13
    max_power: 0.75
light:
  - platform: rgb
    red: output_red
    green: output_green
    blue: output_blue
    default_transition_length: 0.25s
# I suppose these can be 3 globals to work with
globals:
  - id: rgb_r
    type: float
    restore_value: no
    initial_value: "0"
  - id: rgb_g
    type: float
    restore_value: no
    initial_value: "0"
  - id: rgb_b
    type: float
    restore_value: no
    initial_value: "0"
time:
  - platform: sntp
    on_time:
      - seconds: 0
        minutes: 00
        hours: 7
        then:
          - globals.set
              value: # I dont know what to set just the red value
          - light.turn_on:
              brightness: 1.00
              red: 0
              green: 1.00
              blue: 0
          - delay: 950ms
Of course, I need suggestions about how to restore previous values at 8:00
Thank you all
