Gmail notification - Doesn't trigger
Hello
I installed sensor notifications by gmail and when I manually tested it, it works fine. However, when my sensor reaches the point to trigger a notification, it doesn’t work. My sensor works very well, it indicates correctly.
The sensor model is : Tank Level Monitor – LM4110ZB and work with Hubitat correctly integretd under HA
Can you see my configuration and see what doesn’t work?
Thanks for help
Home Assistant - Gmail notification
So your alias is “… under 51%” and your yaml says below: 50.
What is the value of the sensor?
What was the value of the sensor when you created the automation?
And as always, images of text is useless.
Text should only be posted as text.
Please follow the Troubleshooting Automations guide and let us know which step is failing.
Thanks for your fast answer.
Allias suppose to be 50
Bellow 50
When i created the notification, the sensor was at 49
Sorry for the image, i didn’t know.
When i manually try the notification, is work.
Thanks.
Read the note.
doesn’t work. I tried everything???
We cannot help you if you don’t provide information…
Please review the Question Guidelines.
The note says:
Crossing the threshold means that the trigger only fires if the state wasn’t previously within the threshold. If the current state of your entity is 50 and you set the threshold to below: 75, the trigger would not fire if the state changed to e.g. 49 or 72 because the threshold was never crossed. The state would first have to change to e.g. 76 and then to e.g. 74 for the trigger to fire.
You said:
And the automation should trigger below 50.
If it’s still unclear, then read the note again.
Repeat this until it’s clear.
