Go-e Gemini mqqt wont show any values
I installed a go-e gemini, enable MQTT, added a user for the box.
Everything seems to be ok, the Goe app shows connected and I can see the box sending mqtt info (according to the mosquito logs) - still no values or sens are showing any data.
I wonder if this is realted to the “Gemini” version of the box. V1 works fine (without mqtt). Was anyone successful integrating the “gemini” version with mqtt ? if so how ?
Cheers
Andy
well … sorted.
When setting up the integration remove the leading “/” from the base-topic and it will work. It didnt work the other way arround (adding a “/” to mqtt on the app - odd tho).
Thx anyways.
Another Update, just in case anyone is searching for the same issue:
after about 1h I didnt receive any more update. removing the “/” in the application and the app solved it. Sounds odd, but seems to work.
