so, i’ve been “tinkering” with hass for months now. Discovering possibilities, creating automations, making neopixel ring lights using nodemcu with rgb leds,…
but a lot of times, things just… stop working. I don’t think it’s my network because I have a really fast and stable network. But i keep getting a lot of “unavailable” 's, interruptions,…
For example, I have set up an automation that, when my honeywel T6 smart thermostat goes from “off” to “heat”, a neopixel light (via nodemcu in esphome) turn on green, and when I turn my thermostat off, if blinks white 2 times and turns off. but sometimes the nodemcu isn’t reachable, so the automation doesn’t run properly, so I don’t know if the heating is off or on.
I could go for only philips hue lights, but it would spend 50€ just for a “warning sign for the thermostat”
are there other, more stable “arduino-like” things that I can use? that work under more conditions?
I have bought 15 nodemcu’s from different brands, and only 3 of them still work properly after a year. and it’s not the wifi or the distance, because the ones still working are the farthest away from the router and the cheapest.
What software are you running on the NodeMCU ESP8266 boards? Also, a decent quality power supply is a must, from my experience. Like you, and have been tinkering with Hass for a few months. I have been trying ESPHome on ESP32 and ESP8266 based NodeMCU style boards. I have a UniFi wireless network and everything has been stable in my testing, but it’s all on the workbench, not deployed throughout the house.
I have Telenet (a provider that uses his own router) with a second Access point.
(modem: DOCSIS 3.1 WIRELESS (DOCSIS)
I have a 3rd linksys router that I use in bridge mode where I connect my nodemcu’s to.
I seperated my 2.4 and 5 ghz network to see if it makes a difference.
but it’s really hard to find out what the connection issues are.
I’ve been thinking about restarting from scratch, and setting up everything from zero, but it’s going to be a lot of work.
