The Tesla app and the local web interface has an option to go off grid.
There are times that I would like to go off grid and being able to schedule/automate it would be much better.
Is it possible to add this option to the HA integration? (Probably as a switch)
In my case I actually want to go off grid during the day, while I’m generating solar.
Reason being, while solar is generated it needs to sync phases with the grid, and to do this the grid is constantly supplying about 100W. This usage adds up during the day and could be as much as 5% of my total usage on a day.
So going off grid during the day helps me decrease my dependency on the grid even more.
You’re super welcome @justanothernaude! I was in the same boat as you, and desperately wanted to be able to automate taking my home off grid (negative feed in tariffs from my provider ).
I’ve had some feedback that it curtails solar generation correctly for single phase systems (should work for most installations) but won’t if you have a three phase setup. Not much I can do here, I’ve just plumbed in the off grid switch from the Web UI.
Sure, finally got around to sorting those out today and happy to share (though I wouldn’t be surprised if I have bugs, it’s my first draft).
My main use case is to take my home off-grid if the solar feed in price goes negative (which unfortunately my provider seems to do whenever the sun is out ) and my battery is almost full. For a single-phase powerwall setup (the standard setup, as far as I’m aware), switching on “Go Off-Grid” curtails your solar and avoid exporting solar to the grid, which is what I’m taking advantage of here.
binary_sensor:
# Note: this is coming from the Amber Energy integration, you may need to get the feed in price from another integration depending on where you live!
- name: Amber Energy Negative Feed In
platform: threshold
entity_id: sensor.<YOUR SITE NAME>_feed_in_price
lower: 0
- name: Powerwall Almost Full
platform: threshold
entity_id: sensor.powerwall_charge
upper: 95
automation power:
- id: power_automatically_go_off_grid
alias: "Power: Automatically go off-grid"
description: ""
mode: single
- platform: homeassistant
event: start
- platform: state
entity_id:
- binary_sensor.amber_energy_negative_feed_in
- binary_sensor.powerwall_almost_full
- choose:
- conditions:
- alias: "Negative Feed In && Battery almost full"
and:
- condition: state
entity_id: binary_sensor.amber_energy_negative_feed_in
state: "on"
- condition: state
entity_id: binary_sensor.powerwall_almost_full
state: "on"
sequence:
- if:
- condition: state
entity_id: switch.home_energy_gateway_off_grid_operation
state: "off"
then:
- service: switch.turn_on
data: {}
alias: Go off-grid
alias: Go off grid, if we aren't already off-grid
default:
- if:
- and:
- condition: state
state: "on"
# Note: adding this second condition in case you have a grid outage while you're off-grid... Not sure it's necessary
- condition: state
entity_id: binary_sensor.grid_status
state: "on"
then:
- service: switch.turn_off
data: {}
TL;DR:
if battery_charge > 95% && feed_in_price < $0.00
Turn on "Off-grid operation"
else
Turn off "Off-grid operation"
Hopefully that gives you an idea of what I was hoping to achieve anyway! Let me know if you want any clarification
- condition: state
state: "on"
When switch.powerwall_off_grid_operation is on, then binary_sensor.grid_status is off, so it is indeed not necessary
Ahh, that’ll be why I was having so much trouble getting my powerwall back on grid (and a separate power outage automation kept triggering). Thanks for the clarification!
Once I iron out the kinks I’ll post a final version too
I did, but I’ve actually had the automation disabled for a while: it’s winter here so I’m not getting much sun, and so the monetary aspect is very, very small. Plus, as a household we’ve gotten a lot better at using as much energy as possible while generating solar/cheap (dehumidifiers and heaters at the moment).
I’ll almost certainly have another crack at getting it set up in summer though!
Was there something in particular you were trying to get working @s3lkies? Happy to help out
