Go2RTC latest release
User of go2rtc as an AddOn with HACS WebRTC integration - works fine.
The latest HA release has go2rtc built in, but I can’t figure out how to use this? Tried to setup cameras using RTSP thinking this would do the trick with a picture card but this just loads the (slow and sluggish) RTSP stream.
Anyone got this working?
Hello Profile - vantech2020 - Home Assistant Community,
Some folks don’t know that it is enabled using the default_config in configuration.yaml.
If you have that bypassed, be sure to add the go2rtc: integration key.
Hi there,
I have default_config: enabled already in YAML but still no joy?
Fixed.
Added go2rtc: to config and then configured cameras using the HACS WebRTC integration as it seemed to run better than the picture entity.
