Go2rtc not woring on Frigate
Good day,
I have tapo cam, it is working fine with pure go2rtc with go2rtc.yml, I can do 2 way audio without any problems… but in Advanced Camera Card (new frigate card) I got error if I add : live_provider: go2rtc
code:
type: custom:advanced-camera-card
cameras:
  • camera_entity: camera.cam2
I also added:
frigate:
camera_name: cam2
got same thing…
I dont know where is the problem if someone can help…
Thank you
you haven’t shown your frigate config
mqtt:
host: xxxxxxxxxxx
port: 1883
topic_prefix: frigate2
client_id: frigate2
user: xxxxxxxxxxx
password: xxxxxxxxxxx
stats_interval: 60
database:
path: /config/frigate.db
go2rtc:
  streams:
    cam2:
     -ffmpeg:rtsp://usernsme:[email protected]:554/stream1#video=copy#audio=aac#audio=opus
     - tapo://admin:[email protected]
webrtc:
   candidates:
     - xx.xxx.x.xx:8555
     - stun:8555
detectors:
cpu1:
type: cpu
cameras:
  cam2:
    ffmpeg:
      output_args:
        record: preset-record-generic-audio-copy
      inputs:
        - path: rtsp://127.0.0.1:8554/cam2?video=copy&audio=aac
          input_args: preset-rtsp-restream
          roles:
        - record
        - detect
live:
  stream_name: cam2
detect:
  width: 800   #2304
  height: 480  #1296
objects:
  track:
    - person
  filters:
    person:
      threshold: 0.7
snapshots:
  enabled: true
  timestamp: false
  bounding_box: true
  retain:
    default: 1
record:
  enabled: true
  retain:
    days: 0
  alerts:
    retain:
      days: 1
    pre_capture: 3
    post_capture: 3
  detections:
    retain:
      days: 1
    pre_capture: 3
    post_capture: 3
motion:
  mask: 0.806,0.174,0.644,0.162,0,0.148,0,0,1,0,1,0.425,1,0.636,0.96,0.265
Actually I am running Home assistant & Frigate on Synology VM, and this is Frigate log :
s6-rc: info: service s6rc-fdholder: starting
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service s6rc-fdholder successfully started
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service log-prepare: starting
s6-rc: info: service log-prepare successfully started
s6-rc: info: service nginx-log: starting
s6-rc: info: service go2rtc-log: starting
s6-rc: info: service frigate-log: starting
s6-rc: info: service certsync-log: starting
s6-rc: info: service nginx-log successfully started
s6-rc: info: service go2rtc-log successfully started
s6-rc: info: service go2rtc: starting
s6-rc: info: service frigate-log successfully started
s6-rc: info: service certsync-log successfully started
s6-rc: info: service go2rtc successfully started
s6-rc: info: service go2rtc-healthcheck: starting
s6-rc: info: service frigate: starting
2025-04-23 10:40:02.829068498  [INFO] Preparing new go2rtc config...
s6-rc: info: service go2rtc-healthcheck successfully started
s6-rc: info: service frigate successfully started
s6-rc: info: service nginx: starting
2025-04-23 10:40:02.850350661  [INFO] Preparing Frigate...
2025-04-23 10:40:02.858013774  [INFO] Starting NGINX...
2025-04-23 10:40:02.887488005  [INFO] Got IP address from supervisor: 10.179.1.34
2025-04-23 10:40:02.924366858  [INFO] Got WebRTC port from supervisor: 8555
2025-04-23 10:40:05.128811618  [INFO] Starting Frigate...
2025-04-23 10:40:06.332785535  [INFO] No TLS certificate found. Generating a self signed certificate...
2025-04-23 10:40:07.718787611  [INFO] Not injecting WebRTC candidates into go2rtc config as it has been set manually
2025-04-23 10:40:07.882585485  [INFO] Starting go2rtc...
2025-04-23 10:40:08.026888622  13:40:08.026 INF go2rtc platform=linux/amd64 revision=b2399f3 version=1.9.2
2025-04-23 10:40:08.027089984  13:40:08.027 INF config path=/dev/shm/go2rtc.yaml
2025-04-23 10:40:08.028340906  13:40:08.028 INF [api] listen addr=:1984
2025-04-23 10:40:08.035643926  13:40:08.031 INF [rtsp] listen addr=:8554
2025-04-23 10:40:08.035647226  13:40:08.032 INF [webrtc] listen addr=:8555
s6-rc: info: service nginx successfully started
s6-rc: info: service certsync: starting
2025-04-23 10:40:08.858036019  [INFO] Starting certsync...
s6-rc: info: service certsync successfully started
s6-rc: info: service legacy-services: starting
2025-04-23 10:40:08.970954678  127.0.0.1 - - [23/Apr/2025:13:40:08 +0300] "" 400 0 "-" "-" "-"
s6-rc: info: service legacy-services successfully started
2025-04-23 10:40:12.327089354  2025/04/23 13:40:12 [error] 186#186: *2 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-04-23 10:40:12.327121514  2025/04/23 13:40:12 [error] 186#186: *2 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-04-23 10:40:12.853755403  [INFO] Starting go2rtc healthcheck service...
2025-04-23 10:40:17.384955996  2025/04/23 13:40:17 [error] 190#190: *4 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-04-23 10:40:17.384961296  2025/04/23 13:40:17 [error] 190#190: *4 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-04-23 10:40:18.939458097  [2025-04-23 13:40:18] frigate.util.config            INFO    : Checking if frigate config needs migration...
2025-04-23 10:40:18.950874236  [2025-04-23 13:40:18] frigate.util.config            INFO    : copying config as backup...
2025-04-23 10:40:18.952214179  [2025-04-23 13:40:18] frigate.util.config            INFO    : Migrating frigate config from 0.13 to 0.14...
2025-04-23 10:40:18.958454748  [2025-04-23 13:40:18] frigate.util.config            INFO    : Migrating export file names...
2025-04-23 10:40:18.972446323  [2025-04-23 13:40:18] frigate.util.config            INFO    : Migrating frigate config from 0.14 to 0.15-0...
2025-04-23 10:40:18.979782042  [2025-04-23 13:40:18] frigate.util.config            INFO    : Migrating frigate config from 0.15-0 to 0.15-1...
2025-04-23 10:40:18.997486481  [2025-04-23 13:40:18] frigate.util.config            INFO    : Finished frigate config migration...
2025-04-23 10:40:19.056940219  [2025-04-23 13:40:19] frigate.util.services          WARNING : Did not detect hwaccel, using a GPU for accelerated video decoding is highly recommended
2025-04-23 10:40:21.083669029  [2025-04-23 13:40:21] frigate.app                    INFO    : Starting Frigate (0.15.0-6cb5cfb)
2025-04-23 10:40:21.084666238  [2025-04-23 13:40:21] frigate.app                    INFO    : Creating directory: /tmp/cache
2025-04-23 10:40:21.095523751  [2025-04-23 13:40:21] peewee_migrate.logs            INFO    : Starting migrations
2025-04-23 10:40:21.096023127  [2025-04-23 13:40:21] peewee_migrate.logs            INFO    : There is nothing to migrate
2025-04-23 10:40:21.127180894  [2025-04-23 13:40:21] frigate.app                    INFO    : Recording process started: 317
2025-04-23 10:40:21.131441845  [2025-04-23 13:40:21] frigate.app                    INFO    : Review process started: 326
2025-04-23 10:40:21.134329772  [2025-04-23 13:40:21] frigate.app                    INFO    : go2rtc process pid: 105
2025-04-23 10:40:21.159247140  [2025-04-23 13:40:21] detector.cpu1                  INFO    : Starting detection process: 333
2025-04-23 10:40:21.163603932  [2025-04-23 13:40:21] frigate.detectors              WARNING : CPU detectors are not recommended and should only be used for testing or for trial purposes.
2025-04-23 10:40:21.199378413  [2025-04-23 13:40:21] frigate.app                    INFO    : Output process started: 349
2025-04-23 10:40:21.939973505  [2025-04-23 13:40:21] frigate.app                    INFO    : Camera processor started for cam2: 377
2025-04-23 10:40:21.957450361  [2025-04-23 13:40:21] frigate.app                    INFO    : Capture process started for cam2: 381
2025-04-23 10:40:22.424335818  2025/04/23 13:40:22 [error] 186#186: *6 connect() failed (111: Connection refused) while connecting to upstream, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", subrequest: "/auth", upstream: "http://127.0.0.1:5001/auth", host: "127.0.0.1:5000"
2025-04-23 10:40:22.424340058  2025/04/23 13:40:22 [error] 186#186: *6 auth request unexpected status: 502 while sending to client, client: 127.0.0.1, server: , request: "GET /api/version HTTP/1.1", host: "127.0.0.1:5000"
2025-04-23 10:40:26.009830418  [2025-04-23 13:40:26] frigate.api.fastapi_app        INFO    : Starting FastAPI app
2025-04-23 10:40:26.231756538  [2025-04-23 13:40:26] frigate.api.fastapi_app        INFO    : FastAPI started
