I’m currently running HA Supervised in a VM in unRAID. And to get some control over the config files and to be able to test modifications, I’m thinking about removing the OpenZWave (beta) addon, and running ozwdaemon in an external container.
But how can I do this? In the documentation I read that in a HA Core installation you need the MQTT integration with an external MQTT broker (I have Mosquitto running in an external container also), and the OpenZWave integration. But I have HA Supervised. Can I just remove the OpenZWave addon, and use the method meant for Core installation?
This means that my Z-Wave system will consist of the following:
- HA Supervised running in a unRAID VM
- ozwdaemon running in a external container
- mosquitto running in an external container
- MQTT integration added to HA, which points to the mosquitto container
- OpenZWave (beta) integration, which points to the ozwdaemon container
Is this correct?
