At the moment I use a Veraedge for about 6 years, and have plugin/app Reactor which is a very powerfull tool to do automations. At the moment I have HA running in docker on my Synology NAS and connected a conbee 2 to pay with Zigbee.
I have some questions/findings. In Vera you can use/create virutal switches. I use this virtual switch to start an automation which sets my heater on for 10 minutes and of for 15 minutes in a loop, as long as the virtual switch is set to on.
I was a bit disappointed not to find a virtual switch in HA, but only the binary helper. Which is not completely the same, as it toggles. I know Homey also has virtual switches.
How can I solve this in HA?
Tinkerer
(aka DubhAd on GitHub)
January 20, 2022, 2:43pm
2
A switch, virtual or otherwise, is on or off. The binary helper (aka input_boolean
) is also on or off.
They’re functionally the same.
It sounds like your problem is how you’re tackling the automation cycle. Try this:
automation:
- alias: 'Turn it on'
- platform: state
entity_id: input_boolean.whale_watcher
to: 'on'
- platform: state
entity_id: switch.heater
to: 'off'
for: '00:15:00'
condition:
- condition: state
state: 'on'
- condition: state
state: 'off'
- service: switch.turn_on
- alias: 'Turn it off'
- platform: state
to: 'off'
- platform: state
to: 'on'
for: '00:10:00'
condition:
- condition: state
state: 'on'
- service: switch.turn_off
The first automation turns on the heater when either:
the input_boolean
is turned on
the heater has been off for 15 minutes and the boolean is on
The second automation will turn off the heater when either:
the input_boolean
is turned off
the heater has been on for 10 minutes
Cool, thanks, going to play with this this evening!
Adjusting your example, but in my setup I only can use the Conbee II as a service switch to turn on/off.
I changed the heater switch to use a zigbee ninary switch.
And I need to switch on a zigbee binary switch. Am I doing something wrong?
Tinkerer
January 21, 2022, 10:45am
5
You’re looking for devices, look for an entity instead.
I must be doing something wrong, but then I also see only this:
I got it, I had to change the action to use the device.
- id: '164236275412'
alias: Turn it on
- platform: state
to: 'on'
- platform: state
entity_id: light.icasa_iczb_iw11sw_9ba1c0fe_on_off
to: 'off'
for:
hours: 0
minutes: 0
seconds: 5
condition:
- condition: state
state: 'on'
- condition: state
state: 'off'
- type: turn_on
device_id: 7d5a2d13204d22d77455e990d735c9e5
domain: light
- id: '847236275412'
alias: Turn it off
- platform: state
to: 'off'
- platform: state
to: 'on'
for:
hours: 0
minutes: 0
seconds: 5
condition:
- condition: state
state: 'on'
- type: turn_off
domain: light
In this case, when I set the helper switch ON, the isaca switch goes into a loop going ON and OFF for 5 seconds.
Thanks!
EDIT:
How to prevent the this: When I turn On icasa switch directly, it also goes to Off after 5 seconds.
Tinkerer
January 21, 2022, 12:12pm
8
Ah yes, you said switch so I assumed switch, not light
You have to match the service to the entity - light
services on light
entities, etc
