So this is the first week I’m really back at my work bench and I’ve discovered much to my surprise, it seems I’ve been using my workbench as a ‘dumping ground’ for various items for the last 2 months. This will of course immediate attention so I can break out all my more delicate electronics gear & get to work. Hopefully I’ll get this wrapped up within 24 hours so the work can begin again.
But during the last two months I’ve been quite busy with my aquarium and a few substantial changes have taken place. The first, being I had to suspend rearing out all the baby clownfish my two pairs were producing - too much supply!
Secondly, I found it necessary to re-engineer the water conduits under our floor to support a 3rd display aquarium to the overall “main system”. Until that point, the 200 liter grow out tank for the baby clownfish was an independent standalone system. And since this 3rd display was already close to the ground (under the big reef tank) - I had to go through the trouble of lower the existing pipe fittings and even the sump, to make the water levels and flow rates work out & safe.
And while I previously had at one point up to three stand alone 10 liter Fry tanks, I also added one of those fry tanks also to the main system (I still need to update the “Tank View” to reflect the fry tank changes).
However, the expansion of the system to incorporate the 200 liter allowed me the first time to investigate my pipes for the risk of something (not found to be present, btw) that I had long wondered about: How will using my main circulation pipes as a food delivery path, negatively be affected by encouraged organic growth, buildup and blockage? I got to find the answer to that when I cut into the pipes I’d been using the last 10 years for that.
It should be mentioned, I did not just start doing this and achieve success, without a reasoned analysis long ago into the potential problems and how to successfully mitigate them by making some additional trade offs (read: investments of time and solutions). I’ll write more about this and explain in greater detail later, but in short when applied with the correct methodology to mitigate against the risks of impact, I found success without realization of risk (blocked pipes or accelerated growth within the pipe lines). And after my findings just a couple of months ago, I wrote those mitigations into part of the “Centralized Feeding Mode” that is part of my HA Aquarium Controller, so I don’t have to manually perform them anymore. For people with Interconnected tank setups, this could be an attractive and sustainable solution.
That said, I am thinking of adding some flow meters eventually to the solution. I could see where it might be interesting to monitor flow rates over the short and long term.
Sadly, one of my 3 recycled APC Masterswitches gave up it’s ghost, and I had to substitute a couple of powerswitches instead, which I find aren’t as quite as responsive as the APC gear.
I’m looking at some more modern and perhaps customized replacements such as some of these for power control, since they’re certified for both AC/DC usage.
And lastly (for now) here’s the latest screenshots of my setup. As you can see, HA takes care of a variety of items, like co-ordinated mixing of Kalklwasser & dosing (so as not to do at the same time), automatically pumping collected skimmate after a certain level has been collected down the drain, temp regulation and monitoring of all the aquariums, water level monitoring (I’ll be adding more sensors for this soon) at various points, and even automated reactions if an event happens. If any of the Pi controllers goes off line, even elements of the network, it’ll get hard rebooted, etc. The water change automation has been awesome.
BTW, the Anemone tank is not overflowing as indicated here in the screenshots. My cat did that by chewing through the sensor wire & I still need to fix and better secure that wire.
