Good morning Automation does not trigger
Hi there,
I created an automation. This should trigger an Alexa greeting every morning.
So far this has never been triggered. This morning I tested it again, unfortunately it doesn’t work.
What can be the reason?
Here the automation:
alias: Guten Morgen Bad
description: ''
  - type: motion
    platform: device
    device_id: 66dfc7837dc98ce07e01289bfdf5195f
    entity_id: binary_sensor.lumi_lumi_sensor_motion_aq2_8190c306_ias_zone
    domain: binary_sensor
condition:
  - condition: time
    after: '05:00'
    before: '07:40'
  - condition: template
    value_template: >-
      {{ now() - timedelta(hours=18) > state_attr('automation.guten_morgen_bad',
      'last_triggered')  }}
  - choose:
      - conditions:
          - condition: time
            after: '05:00'
            before: '06:15'
            weekday:
              - mon
        sequence:
          - service: notify.alexa_media_bad
              message: Guten Morgen Montag
                type: tts
          - service: media_player.play_media
              media_content_id: Alexa.Joke.Play
              media_content_type: sequence
              entity_id:
                - media_player.bad
      - conditions:
          - condition: time
            weekday:
              - tue
            after: '05:00'
            before: '06:15'
        sequence:
                type: tts
              message: Guten Morgen Dienstag
              media_content_id: Alexa.Weather.Play
              entity_id:
                - media_player.bad
      - conditions:
          - condition: time
            after: '05:00'
            before: '06:15'
            weekday:
              - wed
        sequence:
                type: tts
              message: Guten Morgen Mittwoch
              media_content_id: Alexa.GoodMorning.Play
              entity_id:
                - media_player.bad
      - conditions:
          - condition: time
            weekday:
              - thu
            after: '05:00'
            before: '06:15'
        sequence:
                type: tts
              message: Guten Morgen Donnerstag
              entity_id:
                - media_player.bad
      - conditions:
          - condition: time
            after: '05:00'
            before: '06:15'
            weekday:
              - fri
        sequence:
              message: Guten Morgen Freitag
                type: tts
              media_content_id: Alexa.TellStory.Play
              entity_id:
                - media_player.bad
      - conditions:
          - condition: time
            weekday:
              - sat
            after: '06:00'
            before: '07:55'
        sequence:
I’m grateful for any help.
Greetings Werner
Have you tried the “old fashioned” trigger?
  - platform: state
    to: 'on'
Furthermore have you checked the “Debug Automation”? Does it really not trigger or is one of the conditions wrong?
Hi there,
Yes, I have already integrated the sensor in different ways.
Unfortunately, I don’t know anything about the debug.
Unfortunately I can’t get any further.
Greetings Werner
No problem :slight_smile:
There is a extensive documentation about getting started with “Automation Debug” view:
Troubleshooting Automations - Home Assistant (home-assistant.io)
type: tts
is missing in your text messages. Try this way:
                type: tts
Hi there,
The thing with tts is strange. It’s in the user interface and the command runs flawlessly in the test.
I looked at that with the debug. Unfortunately my English is bad.
I’ll keep trying.
Greetings Werner
Is it possible that the following condition is to blame:
condition:
    value_template: >-
The problem. The automation has never been executed. It is therefore not possible to compare the 18 hours.
Will now trigger the automation manually. Then I will set the condition to one hour and monitor again.
Greetings Werner
At least I understand debug a little now.
Just note, that manually triggering will not consider the condition. But you can set the state of your binary sensor in Dev Tools → States (Entwicklerwerkzeuge-> Zustände, dort: Status setzen)
Yes I did. Now get the following result:
I’m an idiot. It dropped with copying your automation in my editor.
For testing purposes I’ve set the timedelta to 1 minute, and the automation runs flawless when triggering it with one of my motion sensors:
      {{ now() - timedelta(minutes=1) > state_attr('automation.guten_morgen_bad',
With this setting it works fine for me. I don’t understand where the mistake was…
That will still fail if the automation has never been triggered. The left hand side of the comparison will evaluate to a datetime object but the right hand side will evaluate to None. I tested it in the Template Editor using an automation that has never been triggered (no value for last_triggered) and the result is:
TypeError: '>' not supported between instances of 'datetime.datetime' and 'NoneType'
Faulty testing procedure, because the suggested template fails for the same reason your original template did.
For future reference, this version handles the case where last_triggered has no value. If the automation has never been triggered, default(today_at(), true) supplies a datetime object set to the current day at midnight.
{{ state_attr('automation.guten_morgen_bad', 'last_triggered') | default(today_at(), true) < today_at('05:00') }}
EDIT
Correction. Removed unwanted \u200b character from template.
Great !!!
Thank you all. So now I can implement it.
Greetings Werner
Oh no:
When I enter the following message comes up:
Message malformed: invalid template (TemplateSyntaxError: unexpected char ‘\u200b’ at 63) for dictionary value @ data[‘condition’][0][‘value_template’]
Message malformed: invalid template (TemplateSyntaxError: unexpected char '\u200b' at 63) for dictionary value @ data['condition'][0]['value_template']
\u200b is a “zero-width-space” in Unicode and it’s the 63rd character in the line; it’s just before the | character.
It seems that it was introduced when I copy-pasted the template into the forum post (not sure how). I have removed it from the original example.
Either delete the space before the | character (and optionally replace it with a space) or delete the entire template and copy-paste the revised example posted above.
super. Jetzt funktioniert es.
Der erste Live-Einsatz hat wunderbar funktioniert.
Vielen Dank.
