Good practice for automation infrastructure
Not sure if this is the right title for my question, but what I’m trying to acomplish is:
  1. Base Automation (blueprint) that adapts the lights from X brightness & color to Y brightness & color, starting at time A, ending at time B, stops the change when a manual change is made
    Multiple automations will be based on this blueprint with different start/end times and light values.
    This blueprint is finished and working
  2. Actionable Notification Automation/script that if in the Base Automation a manual change is made, I receive an actionable notification on my phone after X minutes that asks me to continue the light change. If I reply “Yes” it will continue from the light settings at that moment
    This is not yet finished, but I’m working on it.
  3. Time Home Automation that when I get home, it turns on the lights with values based on the time I get home (either bright and cool lights in daytime or dimmed and warm at night), then it calculates how long from that point until the next Base Automation will start and after X amount of minutes, it gradually dims the lights until the desired start values from the next automation based on Base Automation are reached.
Now that I’ve finally finished my first blueprint Base Automation, I want to amplify the automation by the functions 2 and 3. I’m looking for tips and ideas to use these automations efficiently and have them work together (Time Home knows when next script from Base Automation is running).
What actions should be combined into 1 automation and which shouldn’t?
What actions should be run in a script and which in an automation?
In case this makes my idea a bit more clear, below is the blueprint Base Automation (currently in script form, because I haven’t tested the automation version yet)
blueprint:
  name: AL ES Adaptive Lights
  description: Change lights based on time of day
  domain: script
  input:
    target_light:
      description: The light(s) with kelvin
      selector:
        entity:
          filter:
            - domain:
                - light
          multiple: true
    start_time:
      description: Time to start the automation
      selector:
        time: {}
      default: null
    end_time:
      description: Time the script should end
      selector:
        time: {}
    start_template:
      description: Start based on a template
      selector:
        template:
      default: false
    steps_per_minute:
      name: Steps per minute for all runs
      description: Used for configuring percentage of each step for brightness and color temperature
      default: 5
      selector:
        number:
          min: 1
          max: 12
    start_kelvin:
      description: Start Kelvin value
      selector:
        color_temp:
          unit: kelvin
      default: ""
    end_kelvin:
      description: >-
        Target Kelvin value
      selector:
        color_temp:
          unit: kelvin
    start_bright:
      name: Start brightness
      description: Start brightess percent
      selector:
        number:
          min: 1
          max: 100
      default: ""
    end_bright:
      name: Maximum Brightness
      description: End brightness percent
      selector:
        number:
          min: 1
          max: 100
      default: ""
    manual_override:
      name: Input boolean for manual changes
      description: Stop change of lights when manual change is made
      selector:
        entity:
          filter:
            - domain:
                - input_boolean
    reminder_continue_change:
      name: Reminder to continue light change
      description: >-
        Send an actionable notification after time has passed to continue the light change
      selector:
        time: {}
      default: "00:30:00"
mode: single
variables:
  start_time: !input start_time
  end_time: !input end_time
  steps_per_minute: !input steps_per_minute
  start_kelvin: !input start_kelvin
  end_kelvin: !input end_kelvin
  start_bright: !input start_bright
  end_bright: !input end_bright
  manual_override: !input manual_override
  duration: >
    {% set start = strptime(start_time, '%H:%M:%S') %}
    {% set end = strptime(end_time, '%H:%M:%S') %}
    {% if start > end %}
      {% set end = end + timedelta(days=1) %}
    {% endif %}
    {{ (end - start).total_seconds() / 60 }}
  intervals: "{{ duration * steps_per_minute | int }}"
  step_kelvin: "{{ ((end_kelvin - start_kelvin) / intervals) }}"
  step_bright: "{{ ((end_bright - start_bright) / intervals) }}"
sequence:
  - variables:
      step_kelvin: >
        {% if start_kelvin < end_kelvin %}
          {{ (end_kelvin - start_kelvin) / intervals }}
        {% else %}
          {{ (start_kelvin - end_kelvin) / intervals * -1 }}
        {% endif %}
      step_bright: >
        {% if start_bright < end_bright %}
          {{ (end_bright - start_bright) / intervals }}
        {% else %}
          {{ (start_bright - end_bright) / intervals * -1 }}
        {% endif %}
  - service: light.turn_on
      entity_id: !input target_light
      brightness_pct: "{{ start_bright }}"
      color_temp_kelvin: "{{ start_kelvin }}"
  - delay:
      seconds: 2
  - repeat:
      until:
        - condition: or
          conditions:
            - condition: state
              entity_id: !input manual_override
              state: "on"
            - condition: template
              value_template: "{{ repeat.index == intervals | int }}"
      sequence:
            brightness_pct: "{{ (start_bright + (step_bright * repeat.index)) | int }}"
            color_temp_kelvin: "{{ (start_kelvin + (step_kelvin * repeat.index)) | int }}"
        - delay:
            seconds: 2
Hello Elise,
Thanks for contributing to the community with a new Blueprint.
I have a suggestion for you. Many people who are not familiar with directory structures will have problems installing this without the Home Assistant MY tools.
Adding a MY link for this Blueprint to your top post would help them a lot.
Here is the link to make that.
Create a link – My Home Assistant
