Goodwe ET series - Modbus adress missing
Hello all, after many problems with connectin via Wifi I connected my Goodwe across modbus.
I have a problem with some states, which I can´t find in documentation or doesn´t avaible for me :frowning: I need adress for Day_buy_energy and Battery_power (± power to and from battery) Does anyone have a solution?
Thank you :wink:
Hi, Have you moved forward with your problem?
Thank you
Jaroslav
Here is Goodwe manual with modbus adress and flows from NodeRed. All works fine with Elfin LAN/RS485
https://uloz.to/file/o7l2ARrm5Bhh/modbus-protocol-hybrid-arm205-v1-7-etehbtbh-readdataonly-pdf#!ZJEyMGR2AGAyLGZ5LwOyMJZjLmAuA2ubDwIUqyb3AF4lGQVjZj==
https://uloz.to/file/uO3iMtckho1S/flows-modbus-json#!ZJD5BQR2AmSvMTVlZGSyAwN0AwWxLIZko2ujE3b5AmHhLGZkZt==
Hello, could you please assist me with the configuration of Goodwe in NODE RED? Uložto is no longer available, and I have some parts of the configuration, but I’m struggling with others. I would like to examine a template to better understand the issue. Thank you.
also interested in this
