abasel
(Andre)
November 2, 2024, 2:54am
1
TimSoethout/goodwe-sems-home-assistant: Sensor for Home Assistant pulling data from the GoodWe SEMS API for solar panel production metrics. refers to adding the following optional template:
sensors:
pv_temperature:
value_template: '{{ states.sensor.inverter_$NAME.attributes.tempperature }}'
unit_of_measurement: 'C'
friendly_name: "PV Temperature"
pv_eday:
value_template: '{{ states.sensor.inverter_$NAME.attributes.eday }}'
unit_of_measurement: 'kWh'
friendly_name: "PV energy day"
pv_etotal:
value_template: '{{ states.sensor.inverter_$NAME.attributes.etotal }}'
friendly_name: "PV energy total"
pv_iday:
value_template: '{{ states.sensor.inverter_$NAME.attributes.iday }}'
unit_of_measurement: '€'
friendly_name: "PV income day"
pv_itotal:
value_template: '{{ states.sensor.inverter_$NAME.attributes.itotal }}'
friendly_name: "PV income total"
pv_excess:
value_template: '{{ states.sensor.inverter_$NAME.attributes.pmeter }}'
unit_of_measurement: 'W'
friendly_name: "PV spare"
# battery soc
pv_soc:
value_template: '{{ states.sensor.inverter_$NAME.attributes.soc }}'
unit_of_measurement: '%'
friendly_name: "Battery power"
Looking at the below, I cannot work out where this might be stored:
Sir_Goodenough
((SG) WhatAreWeFixing.Today)
November 2, 2024, 4:45am
2
Hi Andre ,
While it is possible to make that work, that is the legacy syntax for making those and you can’t find it easily in the Docs because that way was replaced years ago. You should complain to the source of that information that they need to fix this problem…
This should be put into your configuration,yaml file. If there is already a template: section in there, skip the template: key and put this under that key. Otherwise paste this into configuration.yaml as-is.
template:
- sensor:
- name: pv_temperature
unique_id: 9c46ac94-7647-4e61-95f1-f2fee2d28531
state: '{{ states.sensor.inverter_$NAME.attributes.tempperature }}'
attributes:
- name: pv_eday
unique_id: 04fcd3a0-8a76-4726-b880-5c813621b69d
state: '{{ states.sensor.inverter_$NAME.attributes.eday }}'
attributes:
- name: pv_etotal
unique_id: b1859f54-bdf5-410c-9c2b-b2e3e44b745c
state: '{{ states.sensor.inverter_$NAME.attributes.etotal }}'
attributes:
- name: pv_iday
unique_id: 5bc455c0-759b-4d13-8438-fbdbd65b6bc3
state: '{{ states.sensor.inverter_$NAME.attributes.iday }}'
attributes:
- name: pv_itotal
unique_id: 832c97f9-0615-432b-9940-371ab5a3e7c5
state: '{{ states.sensor.inverter_$NAME.attributes.itotal }}'
attributes:
- name: pv_excess
unique_id: 61de79ae-42b0-4a0e-8650-589bcf0d1fe7
state: '{{ states.sensor.inverter_$NAME.attributes.pmeter }}'
attributes:
# battery soc
- name: pv_soc
unique_id: 3c232643-427b-48c1-8a77-443a9ed6c2ba
state: '{{ states.sensor.inverter_$NAME.attributes.soc }}'
attributes:
NOTE:
You may also want ot need to add availability: and state_class: information to these to take care of what happens if the sensor goes offline and to put these numbers into Long Term Statistics.
I have added a unique_id so you can see these values in the UI.
