Goodwe sensor
Hi, I tried to integrate GitHub - TimSoethout/goodwe-sems-home-assistant: Sensor for Home Assistant pulling data from the GoodWe SEMS API for solar panel production metrics..
It still works, but I can´t get the values for the optional sensors.
Is it correct, to put the code below into the configuration.yaml?
platform: template
    sensors:
      pv_temperature:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.tempperature }}'
        unit_of_measurement: 'C'
        friendly_name: "PV Temperature"
      pv_eday:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.eday }}'
        unit_of_measurement: 'kWh'
        friendly_name: "PV energy day"
      pv_etotal:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.etotal }}'
        friendly_name: "PV energy total"
      pv_iday:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.iday }}'
        unit_of_measurement: '€'
        friendly_name: "PV income day"
      pv_itotal:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.itotal }}'
        friendly_name: "PV income total"
      pv_excess:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.pmeter }}'
        unit_of_measurement: 'W'
        friendly_name: "PV spare"
      # battery soc
      pv_soc:
        value_template: '{{ states.sensor.inverter_$NAME.attributes.soc }}'
        unit_of_measurement: '%'
        friendly_name: "Battery power"
