Hi there.
I’m stuck in the process to get data from my inverter an use it in HA. I need to understand this JSON data from the buttom.
From MQTT Explore I can read the data but I don’t now if is recieved correctly.
All explanations says that it should be in home/goodwe/xxxx but my tonic is just goodwe? Is this right?
The MQTT message from
goodwe/13000SSU12700528/data
looks like this.
"address": 11,
"addressConfirmed": true,
"inverterType": 1,
"isOnline": true,
"lastSeen": 1610272800307,
"runningInfo": {
"eDay": 0.1,
"eTotal": 25499.5,
"errorMessage": [],
"fac1": 49.99,
"fac2": 0.0,
"fac3": 0.0,
"function": 129,
"gcfiFault": 0,
"hTotal": 33475,
"iac1": 0.5,
"iac2": 0.0,
"iac3": 0.0,
"ipv1": 0.4,
"ipv2": 0.0,
"line1FFault": 0.0,
"line1VFault": 0.0,
"line2FFault": 0.0,
"line2VFault": 0.0,
"line3FFault": 0.0,
"line3VFault": 0.0,
"pac": 82,
"pv1Fault": 0.0,
"pv2Fault": 0.0,
"temp": 24.4,
"tempFault": 0.0,
"timestamp": "20210110110000",
"vac1": 226.8,
"vac2": 0.0,
"vac3": 0.0,
"vpv1": 174.6,
"vpv2": 0.0,
"workMode": 1
"serial": "13000SSU12700528",
"serialNumber": [
49,
51,
48,
48,
48,
83,
83,
85,
49,
50,
55,
48,
48,
53,
50,
56
But how do I read this data in HA. I tried with node-red but that seems to me a little comple. I tried to read the info in Configuration.yaml but it dosen’t work at all. Therefore I just need a basic how to get moving on.
Cheers
Soren
