So, both, google and amazon fail to do the redirect.
I suppose it could be the same issue.
Google:Error 400: redirect_uri_mismatchYou can’t sign in to this app because it doesn’t comply with Google’s OAuth 2.0 policy.If you’re the app developer, register the redirect URI in the Google Cloud Console.Request details: redirect_uri=https://my.ha.com:8123/auth/external/callback
I’ve got the same exact problem trying integrate Google Nest Thermostat with Home assistant. In API Credentials I added the redirect url of “Link to OAuth2 Authorize Callback – My Home Assistant”, but I too get Invalid parameters given. Hoping someone can help us out.
That’s right, i remember that checking the log made me update URL properly. Sadly, now, i can’t figure out much. I’ll try to post later when i recreate the issue, what is happening in the log.
I got it to work, but here is where I found the logs. I went into Settings and then System and then Logs. It was the first one on the top since I didn’t do anything after that error.
To get it to work, after about 10 unsuccessful attempts, I decided to do a fresh start and I restored my Home Assistant from a backup I had saved just before trying to add Google Nest. You may not be able to do that but you can try the rest that I did.
I then deleted everything I created on Google and started from scratch there following the steps from that YouTube video you used. I think my problem was that I used mixed case in the name. Example: I had used Ha-nest instead of all lower case like ha-nest. I think everything is case sensitive. I also noticed when I did a double click to select the Client secret and device access project id to copy/paste, it added a space to the end of the line. I made sure I didn’t have any leading or trailing spaces in any of the copy/paste from Google to Home Assistant the time it eventually worked. When I got to linking the account, it found my nest thermostat and added it to dashboard. Hope it works for you. If you don’t want to restore from a backup, still delete everything from google and do those steps again and make sure you don’t have spaces and letter cases are same. Hope it works for you too.
