Google Assistant addon 1.1 stop working
hello, Pvizeli has updated to 2.0, and now it works (at least to me it is working) and finally it works also in other languages ​​(for which German, English, French, Italian)
I’m only seeing 1.5, do I need to do something different to see 2.0?
Edit Nevermind, re-installed and now it’s showing 2.1
I’m really struggling getting this new version to run. After opening the webui and pasting in the auth code it’s not doing anything but leaving me with a message to run hass.io googleassistant sdk.
I tried creating a new oauth and json file but unfortunately still no luck… Anyone else having issues?
Seems to be working ok here. Only problem is the volume is very low. Can barely hear the response.
“hey google volume up” works nicely! all working well now
I managed to get it. I just started over from scratch and everything worked right off the bat.
Cheers.
Hi Craig,
How did you register your device?
Never mind, I got it!
Could anyone to direct me where I can get the auth code. After I press OPEN WEB UI I get a text field and ‘Connect’ button. Pressing the button without entering, as I understand’ some token open page with an error ’ Error: disabled_client’:
A native application: project-877980674376
You can email the developer of this application at: [email protected]
This app is not yet configured to make OAuth requests. To do that, set up the app’s OAuth consent screen in the Google Cloud Console."
Could anyone help to resolve it. Thanks in advance.
