Google Assistant addon for HassIO installation problem
Hi, I am not able to install the Google Assistant addon on HassIO. When I press the install button, the installation process breaks after about a minute and Home Assistant restarts itself. Any idea how to fix this?
Ok, I think i fixed the problem. My Hass.IO installation runs on a Raspberry Pi 3 and until now I used an cheap 5v smartphone charger to power it. I replaced it through a better power supply and everything works fine now.
So if you have stability problems with Hass.IO on your raspberry pi, try another power source. Maybe this could save you a lot of time :slight_smile:
