I think I’ve exhausted all the google help out there. I just can’t seem to get any voice command to work. I started a bit complex trying to get a custom sentence to work and have now scaled back to just trying to get anything to register from Google to HA.
I’m starting to think I’m missing some fundamental aspect of the design. I have a v2.0 google mini assistant. It’s registered with Nabu and Google Home sees devices from HA. My HA has cloud configuration setup and running.
Should I be able to issue a command to google and have it trigger an action in HA?
I have this “simple” test in my configuration.yaml file:
conversation:
intents:
SetVolume:
- "Set [the] TV volume to {volume}"
intent_script:
SetVolume:
speech:
text: "Great! Test Worked."
Shouldn’t that simply return “Great! Test Worked” via Google when I give it the command of “Set TV volume to 4”?
Google complains that it can’t control that device because it isn’t linked to it. It doesn’t seem to know that it needs to give control to HA?
