Google Assistant and HA -> Rooms
I’ve been using the manual Google Assistant integration for a long time. I didn’t use the cloud.
When I add a device to a room, it is also displayed or sorted accordingly in Google Home.
But if I change a room on a device in the home assistant, this change is not applied - even a “synchronize my devices” does not bring any success.
A restart of Home Assistant was also unsuccessful. Only when I disconnect and reconnect the connection between HA and Google Assistant are the devices added to the rooms.
Is that normal? A room change should actually be possible immediately without any problems - right?
greeting
Herbert
